Volks AutosChris Nott
    Aug 2010
    leicester
    headlight removal - bumper off or not??
    Hi all, need to check my connections inside headlight unit as one flickers off occasionally when driving, mainly on bumpy roads.
    done a bit of research & had a quick go, got as far as light unit loose in hole, unsupported but cant see a way of getting it out without removing the bumper.
    is this correct? seems a bit stooopid for german engineering if you ask me?
    Richard
    Stepho's Avatar
    Feb 2004
    Strathclyde
    443
    Bumper off is the only way I know. Only takes about 10 minutes though
    Aug 2010
    leicester
    ok, so how does the bumper come off?
    simply i hope.
    Stepho's Avatar
    Feb 2004
    Strathclyde
    443
    Use this step by step guide. You will need an extended 10mm socket to get the 2 nuts under the headlamp on both sides.
    B7 A4/S4: Clear Corner Mod/Removal of Bumper
