Page 8 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 281 to 320 of 667
Like Tree13Likes
Thread: Anyone else with this problem on 2006 2.0 TDi? Injectors...
  1. #281
    jfarhead's Avatar
    176
    Quote Originally Posted by Wonker View Post
    Should they also be replacing the loom?
    Well the loom has not been identified as the cause of these issues so they wouldn't have to, I had mine swapped after each failure because the first time round the injector may have damaged it when it failed.
    Adgard likes this.
    Report to VOSA:
    www.dft.gov.uk/vosa/onlineservices/vehicledefects.htm
    You are covered by the Sale of Goods Act 1979:
    • Goods must "conform to contract", without an error in manufacturing where a faulty component was inserted
    • The seller is responsible for up to six years after purchase
    Facebook:
    http://www.facebook.com/pages/Fix-th...56033921135623
  3. #282
    jfarhead's Avatar
    176
    Quote Originally Posted by Greg Roles View Post
    One can only hope the dealer didn't replace them all, and just said they did.
    Ironic eh, we're hoping that the dealer didn't do his job... I would have suggested it may be the loom, but even a faulty loom frying the injector should not cause this cosidering the whole point of the double seal is to prevent such a scenario. Hopefully it's a one off...
    Last edited by jfarhead; 8th July 2011 at 09:10. Reason: got the quote slash wrong way round
    Report to VOSA:
    Facebook:
  4. #283
    johnny161171's Avatar
    Jun 2011
    Lincolnshire
    56
    Hi i've only recently joined the forum and i have been reading this thread with great interest as i have a 2007 2.0tdi and it seems to be going off a cylinder when idling and just now and again it feels lumpy when having to hold it at a set speed when following traffic i got hold of a fault code reader and it showed fault code 12546 the book says faulty injector but i googled this number and on the net this guy says the most common thing is the inlet manifold so i don't know whether to have a go at Audi about this 1
  5. #284
    May 2011
    10
    Quote Originally Posted by johnny161171 View Post
    I've experienced this lumpy running on occasion, I'm hoping when all my injectors are replaced it will improve this.
    If you have the 2.0TDi 170, then you should contact Audi regarding the injector issues, if you've the 140, the contents of this thread is probably not relevant to your issue.
  6. #285
    v1raj's Avatar
    Apr 2009
    279
    deleted
    2006 Audi A3 (8P)
    Spec - 2.0 TDI l DSG l Sprint Blue l Leather Interior l 18" RS6's | H&Rs | S3 Front | 6k Bi-Xenons | EMTuning DPF Delete Package
    Plans - BBS
  7. #286
    807
    Just got a call from west london audi. They said all 4 my injectors fall into the batch which will require replacement. Audi uk are covering the full cost inc the loom.
    The only problem is there is a shortage of the stress bolts which need to be replaced at the same time... meaning I have to book it in for about 10 days time.
  8. #287
    Jul 2011
    Hi - I'm new to this forum having just bought a 57 plate A4 Avant about 3 weeks ago
    Just under 2 weeks ago, the engine cut out at 30mph, glow light flashed etc and after returning it to Audi, they replaced all 4 injectors FOC.
    However, despite this, it's just done the same thing again 2 days ago on the M3 at 80+mph in lane 3. Needless to say, it was pretty frightening and I've now lost all confidence in what was meant to be our new family car.
    Audi have just called to say they can find no fault with it!! So they're keeping it for a couple of days to see if it replicates itself.
    I'd be really grateful for any insights/suggestions as what to do next, as with 4 new injectors, this is worrying.
    Massive thanks.
  9. #288
    jfarhead's Avatar
    176
    Quote Originally Posted by P Pod View Post
    Massive thanks.
    I would say report this to VOSA, they need to know what is going on with these. They can only act on the information we supply collectively. See the links in my signature.
    Most importantly get part numbers, add them to the VOSA report, and post them on here so all the VAG and parts specialists on this board can comment with their experience (that's how I found out I was given refurbs). You're the second person to report failure on new injectors, but we need to know what Audi have been putting back into the car before openly declaring the "new" ones failing as opposed to refurbs.
    Certainly not good news though...
    Report to VOSA:
    Facebook:
  10. #289
    Jul 2011
    Many thanks for this - I'll look into it this morning...
    P
    Quote Originally Posted by jfarhead View Post
  11. #290
    Mar 2011
    North Wales
    206
    If it has one or more failed injectors then it should not start so how can they say there is no fault
  12. #291
    Mar 2011
    North Wales
    206
    I've had the letter from vosa also and have the car booked in for next week. I've told them and will say again on the day that if they are replacing the parts with the same design then it's a waste of time and I want updated ones fitting.
  13. #292
    807
    From my conversation with AUK and West london audi was that it was updated replacement parts. But there seems to be very little information sharing.
  14. #293
    May 2011
    10
    Had my A4 back this week. I originally had injector no.2 replaced in May, I paid labour and Audi UK paid parts. That has now been refunded and the remaining 3 injectors replaced.
    I asked for the part no. and it is A03G130073TX, which according to information earlier in this thread is the updated part. This is also the part fitted back in may, so the upgraded parts must have been around for sometime.
    They didn't mention changing the loom at all, is there any reason to believe this is required?
  15. #294
    jfarhead's Avatar
    176
    A03G130073TX is the part I was fitted when my number 3 failed in September, along with a new loom. The part failed in May this year. TX as I was told means it is a refurb. If this is the case, then the fault has not been fixed.
    Report to VOSA:
    Facebook:
  16. #295
    May 2011
    10
    Do we know the part number of the updated part that should have been fitted? I was going by information earlier in the thread, but I think we need to clarify the new part number (assuming it does have a new number and not just a new seal).
    Has anyone else had a different part fitted?
  17. #296
    Wonker's Avatar
    Mar 2011
    Miskin, South Wales
    45
    Had the call from Audi. car is booked in to Bridgend Audi for 'injector' inspection and replacement if necessary. This is a result but I've lost a bit of faith so I will be asking for the part numbers of the replacement parts to make sure they don't fob me off with refurbs. Should they also be replacing the loom?
    Took the car in yesterday, the fella dealing with it didn't really know the history of this and told me that they would be using the diagnostic machine to show them if the current injectors were faulty and then acting on it. I told him that was not why I was there and refused to leave until he phoned Audi UK. After the phone call he had written on his pad that he needed just to check the part numbers....exactly what I had told him 30 mins earlier!
    I had a call from him 2 hours later saying that 3 of the 4 injectors were the old style (part number ending with 'M') and only one was the new style (ending with 'T'), this was the one I had replaced a week after purchasing it and means that the previous 68,000 miles had no problems, just bad luck on my part!
    Anyway the car is still there as they did not have the new parts but they are going to replace the 3 and the wiring loom.
    Wonker
    8P A3 2.0 TDi 170 Quattro S Line Sportback
  18. #297
    2,158
    The X on the end means exchange part, so the parts department must get the old injectors back before they will hand over the new one.
  19. #298
    Mar 2011
    North Wales
    206
    Quote Originally Posted by fatbutcher View Post
    That part number was fitted to mine in november so they don't seem to be fitting anything different now
  20. #299
    Mar 2011
    North Wales
    206
    I've just e-mailed John Fitch at vosa to ask if he knows whether the parts they are fitting now have been updated to fix the problem.
  21. #300
    Mar 2011
    North Wales
    206
    A03G130073TX
    > The part number for the injector you have quoted is the modified injector
    > used from September 2010.
    > Regards
    > John
    > John Fitch
    > Vehicle Safety Branch
    > VOSA
    Slightly worrying as jfarhead has already had this part fail
  22. #301
    jfarhead's Avatar
    176
    Number 3 failed 3 times total on my A4, could be something more than just the injector/loom combo?
    Interesting link (from "rotodiesel" on BriSkoda forum), I'll link to facebook when I get a chance: https://sites.google.com/site/1810ma...iezo-injectors
    Report to VOSA:
    Facebook:
  23. #302
    Wonker's Avatar
    Mar 2011
    Miskin, South Wales
    45
    Got the car back with 3 new injectors and wiring loom.
    Old part numbers removed = 03G 130 073M
    Replaced with 03G 130 073T
    Now it's just fingers crossed.
    Wonker
  24. #303
    Nov 2008
    389
    After an excellent proactive response from Audi UK directly (I contacted them with my concerns for safety, family etc - I've had no failure) - just picked up my Avant from Audi York and they have apparently swapped the loom and all 4 injectors as per Audi UK's instructions but could not give the old and new part numbers as I requested as the technician hadn't made a note. Audi UK are calling me on Monday for a follow-up report so I'll get them to double check everything for me. Interesting what was noted on the job card was that injectors 2 and 3 had actually logged some faults on the diagnostics. Also, probably just my imagination, but the car did seem to pull better since the work has been done, but that could be just that I've been driving their courtesy car for the last few days and my old brain can't cope with too many changes at once
  25. #304
    3DTDi's Avatar
    Jun 2011
    Bristol/Gloucestershire
    239
    Similar story with me, no failure but had emailed Audi um with concerns, agreed to replace all 4 if they are the known faulty ones but the dealer are being **** and keep saying they will get back to me for booking the car in but never do. That's Bristol Audi for those of you interested, the customer service stinks and I would avoid like the plague in the future
    A3 2.0TDi 170 S Line Brilliant Black
    Plans: FBMFSW, RNSE MkII, S3 Diffuser and Skirts, OEM Bi-Xenon
  26. #305
    Jun 2011
    Lincolnshire
    56
    I also had hassle with the local dealer trying to explain the problem with these injectors they was aware of the problem with the injectors but told me that there isn't a recall at the moment and there isn't a campain out on these at the moment i even had the receptionist tell me that i already had the updated injectors installed so went home contacted there parts department did a bit of *******tting and he told me that the injectors in my car had been super seeded by a new part number so she was telling me porkies anyway contacted Audi UK and they have now booked it in but the dealer wasn't interested until Audi UK got involved
  27. #306
    Mar 2011
    North Wales
    206
    Same here
  28. #307
    Oct 2009
    166
    Harold Wood Audi only contacted me after Audi UK chased them up.
    When they said to me on the phone "so what appears to be the problem?" it didnt really fill me with confidence.
    I explained but not sure if they were really listening if you know what i mean!
    My car is booked in for the 25th so i have emailed Amie at Audi UK back to fully appraise them.
    They are collecting/dropping off the car so i will not acutally step foot in the stealer.
    When my injectors were replaced by an indie last November they fitted part No.V03G130073TX.
    Reading this thread there appears to be so confusion if they are the modified or reconditioned ones?
    I never had the loom replaced so it will be intersting to see what happens?
    Audi A4 Avant TDI 170 S-Line
    1992 Saab 900 T16S Convertible
  29. #308
    Jun 2011
    Lincolnshire
    56
    Dropping mine off Wednesday looking forward to the stern looks as i walk through reception
  30. #309
    Jul 2011
    BRISTOL
    12
    Has anyone got a set email that we could use, just bought this car and am now a little worried that this may happen whilst driving with kids onboard.
  31. #310
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Have a look at the copy of my email to Audi on page 6
    or click here to see my post
    Our Avant went in this morning, good friendly service so far and have asked them to look into a couple of other things while they have it. All being well we should be collecting the car this evening with 4 new style/updated injectors. Will report back later.
    Wombatwilson likes this.
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
  32. #311
    jfarhead's Avatar
    176
    Here's VAG Ireland giving one of their customers the whole "we can't help you... warranty expired" speil... hope the guy can use the momentum acheived so far to get theirs sorted too.
    PatLimerick on Tue 12 Jul 2011 13:32:
    VW Passat 2.0 TDI Sport - VW Passat 06 Injector Fault, no joy with VW, help! | Motoring discussion | Back Room Forum | Honest John
    Report to VOSA:
    Facebook:
  33. #312
    lespaul's Avatar
    Dec 2010
    Oxfordshire
    59
    Mine is in as we speak. I had the similar "so what's in in for". But as soon as I said Audi UK have asked....they kinda knew what I was on about..
    2.0 TDI 170 S-line SE
  34. #313
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Is it worth me emailing audi UK , my 2.0tdi 2006 (140) run perfect no issues at all, would it be better to leave well alone or get them replaced.
    It's the old saying if its not broke then don't fix it.
    Not sure which way to go.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
  35. #314
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    This problem only effects the 170pd tdi engines so you dont need to worry fella.
  36. #315
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Quote Originally Posted by dubdemand View Post
    Doh I actually knew that as well .
    F
  37. #316
    lespaul's Avatar
    Dec 2010
    Oxfordshire
    59
    Wahoo
    I'm getting mine done without a failure too. Audi UK spoke to the dealership where my motor is at. Just had a call back and its in next Monday, all four injectors and the wiring loom. Thanks Audi UK
  38. #317
    Jul 2011
    BRISTOL
    12
    Just had a call from Audi Uk who advised to book it in with the nearest dealer who will investigate this, Thanks Dubdemand.
  39. #318
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Good result! I have just had a call from Audi who have stripped my engine down and have the old injectors out to get the part numbers. They will be conatcing Audi UK now with this info and expect to have the new injectors and my car ready for collection tomorrow!
    I just have to put up with their little A3 for a little bit longer and all will be well
  40. #319
    3DTDi's Avatar
    Jun 2011
    239
    Mine is now booked in but not till the 2nd of august but the workshop manager seemed to know what he was on about so hopefully all will be good
  41. #320
    jfarhead's Avatar
    176
    I'm guessing nobody has received a cheque yet...
    Report to VOSA:
    Facebook:
