Sky InsuranceBadger5
Page 17 of 17 FirstFirst ... 71011121314151617
Results 641 to 667 of 667
Like Tree13Likes
Thread: Anyone else with this problem on 2006 2.0 TDi? Injectors...
  1. #641
    Sep 2011
    south wales
    114
    It's not the head gasket is it? Check the expansion tank under the bonnet, see if it is milky & smells of toast. Or could it be the DMFW & you're getting clutch smoke, what does the white smoke smell like? Be careful cos' if it's the flywheel, I've heard they can shatter and f**k up the gearbox.
    Hope you sort it, be good to know the fault.
  3. #642
    Mar 2012
    91
    its not clutch smoke, its oily diesel smell, iv been told maybe stem oil seals?
  4. #643
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    White smoke is unburnt diesel getting into the exhaust system, burning oil is blue smoke, black smoke is excessive diesel being burnt. First thing to do is check your fuel filter isn't blocked, strange as it may seem this seems to throw the ECU into having a fit & sends the fuelling all over the place, if the filter is clean then check the injection timing, if the timing is ok check your turbo seals & boost pipes aren't leaking.
  5. #644
    Apr 2012
    Sheffield
    Not been on for a bit as i gave up on it. Been using my trusty corsa b for a few month. Had it on reader only things mine is showing is glow plugs and maf sensor so have ordered them going to get to work on it next week as im off and sick of the uncomfy ride and hassle with the kids. I doubt its going to be just those two things. Been reading up and could be many things by sounds of it. Probably give up on it again and just do my clutch on my 80 v6. Think it looks better then a4 too. Plus it still runs at 202000 mile. Just carnt kill it.
  6. #645
    Jun 2012
    7
    Quote Originally Posted by b19rak View Post
    Mine is running just like yours after having my injectors replaced when cold. Soon as its a bit warm it's perfect and fuel economy is excellent. I called the dealer and they assured me it's nothing they did and they would charge me if they proved that.
    I'm new on here but seems I'm further down the line with this issue. I have a 2007 2.0 tdi (170) and have had the exact same problem.
    I had a break down a while back (probably about a year) due to faulty injectors, one failed but two were replaced (FOC) and the car ran ok, still under warranty.
    Then, recently (1 month ago) I needed the cam belt change and Audi changed the other two injectors.
    Since then I've had this intermittent issue where a slight stutter between 1600-2000 revs happens (but not all the time).
    Took the car back to Audi (saying it was fine until you did the work). they ran diagnostic to find no codes, but it was running fine when they came out for a test drive, damn.
    Few days later it happened again. Went back to audi and again they ran a diagnostic no fault codes stored and running fine again.
    However, yesterday it had a major kangaroo episode (in fourth gear at 35mph), happened in 3rd & 2nd gear (as slowing down) and again in 1st when I tried to setoff again. Didn't turn the engine off and rang Audi saying I'm on the way!!
    They rang this morning, still no fault code and running ok again. However they did say that say that someone else had the "exact same issue" but caused a fault code and was due to the actuator spitting in air with the fuel.
    They have ordered one and it will be replaced monday. I did a search within this forum and sure enough "actuator" and 170p a4 all come up with this fault which seems linked to the injector change (which as i've now found out is actually a recall which was unknown to me, as we - the people - were trying to get this actioned via VOSA. All this has been done "by courtesy" as i've been lucky enough for AUDI to accept this as their responsibility.
    hope this helps others, and fixes mine
  7. #646
    Jun 2011
    NW London
    141
    cheers for the heads up. please let us know if changing the actuator helps.
  8. #647
    Apr 2012
    Sheffield
    Quote Originally Posted by 80quattro View Post
    Mine arent just symptoms now. As on my birthday it cut out completly after juddering and a loss of power for about 300yards. Towed it back home yesterday using the handbrake for brakes which was fun. Engine will start first time but is a knocking/clicking noise on tick over. Clouds of white smoke but wont rev at all. Engine management light has come on now. Going to get my mechanic over from barnsley to try find out the fault. Unless anyone closer to s5 area has a reader?
    Right had the maf sensor and glow plugs replaced as it through these codes up. Was still rough as hell same white smoke to start with. Took round block started to run a little better. Got back home with it sat still reving it for a bit went from white to black. Left to run then it ran spot on. Booked in for mot which was going to take it in today half way to test center started to judder loss of power until its revved hard then black smokes like hell and goes. Didnt put it through mot as will fail on emissions. Mechanic took another look couldnt figure what it could be told him about egr had that cleaned no difference. Hes now geussing at cat convertor. But also came up with list of other stuff it could be e.g injectors oil pump basically all stuff some of you guys have had done only for it not to be fixed.
    Would rather know what it is and fix it rather then just throw money at possible faults only for it not to fix it. Any ideas would be much appreciated. Thanks
  9. #648
    Aug 2010
    1,540
    actuator? which one?
  10. #649
    Feb 2007
    Warwickshire
    46
    Quote Originally Posted by neilenty View Post
    Please let us know if this sorts out the problem. If it does I'll get it done.
    Any idea how much an actuator is?
  11. #650
    Mar 2011
    North Wales
    206
    Are audi saying that this problem is linked to the injector change and are they fixing foc ?
  12. #651
    Feb 2007
    Warwickshire
    46
    Quote Originally Posted by mm707 View Post
    I second that question.
  13. #652
    Sep 2008
    56
    Think the actuator they're referring to is the black plastic one on the front end of the inlet manifold, diaphragm splits apparently and causes power loss. I believe it should operate the inlet manifold flaps.
  14. #653
    Mar 2011
    North Wales
    206
    Quote Originally Posted by max69vk View Post
    Might as well add my mini rant to this thread!
    Now a further 48hrs later (& less than 50 miles) the car is running rough again with a very pronounced splutter at between 1200-1600 rpm, could this be the fuel filter being blocked or am i going to have to make a 3rd trip to the dealer?
    Just got this from an Audi master tec on another forum, seems to be a possible cause for rough idle and splutter ........
    book your car into Audi and ask them to look at the software update for mild hesitation between 1800rpm and 2200rpm.If applicable then I'm sure this will resolve your problem.
    Has anyone here has their software updated ?
  15. #654
    Nov 2008
    389
    Anyone got any info on an ECU software update that is possibly supposed to be done at the same time as the injector swap? Noticed a mention over on the A3 8p forum....
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
  16. #655
    Sep 2011
    43
    Just had recall on mine yesterday via Audi / VOSA. 2008 2.0 tdi 170 sport. BMN engine.
    Letter is headed via Audi & VOSA jointly. Letter heading is 'Customer satisfaction campaign-piezo unit injector'
    Hope everything is going to go smoothly with this? Mines had a bit of a flat spot at the bottom end since I got it, so hoping on some improvement on this.
    She's off to Gilder Audi Sheffield in August. Hoping for a 'right first time' repair on this. I'll report back when she's done.
  17. #656
    wug
    Sep 2012
    Bucharest Romania
    Hi to all,
    I am new here and i was wondering if this issue has been already spread all over the Audi dealers. Like an example, my Audi is on Romanian plate but when i was in vacation this summer in Germany i had same problem with my BRD engine. I was running on the autobahn nearby Landshut and the engine stopped around 140km/h. I had that spring orange light on for 15 sec blinking and engine went dead. I took the car using Adac service to Audi Landshut dealer with cost of 300 euro for 5 km away and have it repared the next day for 830 euro. They had replaced 2 injectors 03G130073TX, 4 X 03G103385A, 5 X N10581101, 1 X 03G103483B.
    They never mentioned anything about Audi issue and act like was my fault. I think this is outrageous and incredible for a premium car. I have already emailed to audi zentrum landshut, and audi germany. Waiting for feedback.
  18. #657
    Sep 2007
    Chester
    48
    I have noticed on here about a software update for the mild hesitation......has anybody had it done and know what cars its applicable too?
    Thanks,
  19. #658
    wug
    Sep 2012
    Bucharest Romania
    Finally, Audi replied my feedback. Full refund with 2 years warranty anywhere in Europe.
  20. #659
    max69vk's Avatar
    Apr 2012
    742
    Have a read of this, it should cover any questions you have & the remedy... 2.0 TDI (BNM) engine sounding rough AFTER injector swap.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  21. #660
    Mar 2011
    North Wales
    206
    I changed the black plastic actuator on mine and in runs much better - no rough idle and no more hesitation. The old one had a split in the diaphragm when I took it apart. What also probably helped was I cleaned all the crud from the inlet manifold flaps whilst it was off and the egr ( though that wasn't too bad ).
  22. #661
    Dec 2013
    Hi I'm experiencing injector failure on my 2008 bpw tdi and wondered did audi change yours FOC , any help would be appreciated
  23. #662
    Nov 2008
    389
    If yours is a 170 pd tdi you should be able to just book it in and get it sorted...
  24. #663
    Dec 2013
    Hi mines the 140 , been reading most of the issues lay with the 170 but wondered if the 140 was covered as well
  25. #664
    Nov 2008
    389
    Only the 170 99.5% that is the case :-)
  26. #665
    Dec 2013
    Thanks for the reply , that's not good news
    I've been quoted £1300 by audi to change one , so not wanting to pay this I put a refurb unit in and no improvement so changed the injector wiring loom but no change ,so back to audi they confirmed still No3 fault , ok injector out swap with No 4 back into audi confirm fault now with 4 so in my mind I'm think ok it's def the injector , purchased another gen recon injector and put this in 4 and guess what still no improvement.so at this stage I'm in to £500 of injectors £320 for audi investigation work £62 for the loom not to mention the time spent doing all this work ,having the car laid up for 3 weeks its driving me mad .......... Any ideas would be great
  27. #666
    Dec 2013
    Mayo. Ireland
    10
    I have the same motor with a few issues. But my misses has the same engine in her A6. Been all over this problem and had a guy messing about swapping injectors. Waste of time. The main issue she had was horrible tick over and occasionally stalling. We sorted lately by having an Audi update on the software and put our own injectors back in. Have done a couple of thousand miles with virtually no problem. Moral of the story is get a set of injectors from a donor if possible to make sure that's what you are dealing with. Hope this is of some relevance to your problem
  28. #667
    Sep 2011
    south wales
    114
    injector woes
    Hi there, this post was just bounced into my inbox cos I had probs with my 140.
    M8 Audi are supposed to be swapping injectors for free on the 170's!!! Vosa have instructed them to do so. Any injectors you've paid for is refundable by audi
    Quote Originally Posted by Russell a4 cab tdi View Post
