Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Jul 2010
    99
    Will a set of alloys with an ET of 35 Stick out to much on my A4 S line?
    Ive ordered some replica S5 twin spoke alloys with an et of 35 but i think i should have ordered et42 am i correct? my current RS6 FIVE SPOKE stock alloys are pretty flush on the front arches although the rears are set in a bit .I think the rs6's are et42?
    can anyone advise.
    cheers jamie
    Stepho's Avatar
    Feb 2004
    Strathclyde
    445
    These will be fine Jamie. Couple of the guys on here are running ET35 19" wheels with no probs. I went with 8.5J ET45 19's and had to fit a 4mm shim on the front as it was a little to close on the suspension arm.
    Jul 2010
    99
    so the fronts wont stick out to far? these are 18's by the way
    Stepho's Avatar
    Feb 2004
    Strathclyde
    445
    The clearance from stut housing to the inside of the wheel will be 8mm MORE
    The outside edge of the wheel will EXTEND an extra 8mm
    Jul 2010
    99
    So will 8mm be to much on the front as they look pretty far out on stock et43 rs6's
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    I'm running 8.5x19 ET25 (225/35/19) on the front & it's just shy of being flush with the wheel arch. ET35 will be fine.
    Yes, ET25 does rub, but only occasionally!
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Jul 2010
    99
    Gone for et42 instead as i like the fronts how they are but will get some spacers for the rear asap
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    ET35 on my B6 1.8t S-line lowered on Eibach pro-street.
    AUDI A4 190T S-LINE.
