Volks AutosSky Insurance
    bearder2006's Avatar
    Jun 2009
    205
    change a brake light bulb
    well how the fook they have changed !!
    well how do you get to change it please
    Bigman's Avatar
    Cornish and Proud!
    Mar 2007
    Nuneaton, Warwickshire
    85
    If you look on the inside of the boot, there should be a little circular cap, prise that off with a screwdriver and then you should have access to a large bolt thing (I forget what tool you need, but it is nothing special) un screw it, being carefull not to drop it, and then the whole light will slide out!
    its pretty simple when you have done it once!
    Adam
    Adam 'Bigman' Phillips
    Audi A4 B7 2.0TFSI S-Line Avant, Red!
    Debadged rear, Full DIS, Cruise, B5 A4 front lower spring seats (15mm lower than B7), XCarlink, RS4 RARB, Factory Fitted BOSE, 2 tone leather interior.
    Future Mods: R-Tech Re-map, H&R Springs, 15mm rear and 12mm front wheel spacers.
    Jul 2009
    London
    60
    i changed one two weeks ago, pop off cap and use locking wheel nut remover ( in tool box by spare wheel) to undo screw.
    Be careful when you prise the 2 clips on the casing to get to the bulb as they seem fragile.
    A4 DTM Revo 2, Miltek turbo back, RS4 ARB, Forge dv. 290 bhp on a cold day!
    Jun 2009
    205
    thanks will do it to day
    Jun 2009
    205
    yes was easy thanks
