If you look on the inside of the boot, there should be a little circular cap, prise that off with a screwdriver and then you should have access to a large bolt thing (I forget what tool you need, but it is nothing special) un screw it, being carefull not to drop it, and then the whole light will slide out!
its pretty simple when you have done it once!
Adam
