    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    B7 Avant Brakes - not great!?!
    Hi there,
    We've had our S Line Avant for a couple of weeks now and everytime I get in and drive it I can't help but notice that the brakes just don't feel as sharp as my Bm'er or my LCR which I owned before it, come to think about it our previous A2 was better as well!
    It will stop but you do need to be quite heavy on the pedal - is this normal or do I need to have a good look at the braking system and consider new pads/fluid?
    As always any help will be greatly appreciated
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,472
    Has the brake fluid been replaced every 2 years? If not it will absorb water and make the pedal soft.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    The pads are probably all glazed up.
    You can try bedding them in again and see how that helps.
    Find a quiet bit of road, and brake from 60 to 5mph hard, but not so hard as to cause the ABS to engage, then accellerate back up to 60. Repeat this 10 times, then once you've done it take the car for a long drive to cool them down again. DO NOT stop when they're hot, or you can cause pad transfer and end up with "warped" disks. If you HAVE to stop for some reason, then brake to a few mph or so then release the pedal and let the car roll to a stop.
    You'll probably find the brakes will smell pretty bad towards the last few stops, ignore this, as thats exactly what your trying to achieve.
    Once they get hot enough, they'll burn off all the glazing and give you decent material back again.
    TD5 Land Rover Defender build
    May 2008
    Surrey
    59
    B7 brakes are pretty much spot on - had no issues at all with them (mine are standard btw). Even the the mrs commented when she first drove it how responsive the brakes were! I dont need to be that heavy on the pedal to bring the car to a standstill from speed.
    Much better feel than my old 8L S3!
    The Libertines - Time for Heroes.....
    "There are fewer more distressing sights than that of an Englishman in a baseball capcap"
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Thanks chaps! I'm not sure when the fluid was last done so that might be in order and I'll also try re-bedding the pads to see if that helps...
    I'm certain they should be better than they are so this seems to be the best place to start!
    I've used Motul RBF600 fluid in the past with Ferrodo DS2500 pads - is this a good combination for the A4?
