    Jul 2010
    99
    Fitting a new rocker cover gasket . Do I use sealant as well?
    I've found my rocker cover gasket is slightly leaking from one corner so have bought a replacment. Is if just a case of cleaning the surface and fitting the new on or is it best to smear some sealant on the faces to help thing along . I know I used to along time ago but wasn't sure about the new stuff.
    Sep 2009
    Mid Sussex
    162
    No you shouldn't need to, new gasket new seal should be fine.
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    Jul 2010
    99
    Ok fitted the new rocker gasket . Haven't got a torque wrench so do I do the bolts up pretty tight ?
    Sep 2009
    Mid Sussex
    162
    Yeah tight as poss without taking the P**s
    A3 1.8t quattro -
