Chris NottSky Insurance
Results 1 to 14 of 14
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Kufatec roof HELP
    Hi all
    Just installing the roof module & it works with the 1 touch on the button inside, but i cant get it to work with the remotes.
    Pissin me off now...
    The functions are working on the mirror stalk as well , but no remote
    Anyone please help
    Ta
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    sounds like you need to recode the car.
    try putting your key in the drivers door lock and unlocking the car, hold it in the unlock position and see if your roof folds down, if it doesnt then your cars not coded correctly and the module wont work.
    do you have vagcom ???
    if you do you need to check that in the comfort module, channel 62 is set to 255
    Channel 062: Comfort Functions
    • +001 = Comfort closing via remote for window regulators (not USA)
    • +002 = Comfort opening via remote for window regulators (not USA)
    • +004 = Comfort closing via lock cylinder for window regulators
    • +008 = Comfort opening via lock cylinder for window regulators
    • +016 = Comfort closing via remote for sunroof (not USA)
    • +032 = Comfort opening via remote for sunroof (not realized)
    • +064 = Comfort closing via lock cylinder for sunroof
    • +128 = Comfort opening via lock cylinder for sunroof (not realized)
    Note: Adaptation value is the sum of the individual options.
    LOTS DONE, LOTS SPENT !!!!
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Ok mate thanks for that . I'll get the Vag on later
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Tried channel 62 mate & it was set to 72 . Reset it to 255 & no joy. Tried the key in the lock and the windows go up and down when the door is opened and closed.
    At a bit of a loss now as the vag is set at the correct settings and its working from the inside switch and i only have to touch the switch once & it self coses/opens.
    I just cant get it to work from the remote.
    The instructions are a bit vague to folllow but there are only 4 modes from the mirror switch.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Sorry forgot to mention that the roof doesn't work with the key in the lock either although Vag tells us something in brackets. Will this be a dealer only setting or am I a module short in the car ?
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    am i right in saying that the kufatec module you have fitted is TWO modules, one in the back quarter ( for the one touch ) and the other in the drivers door card ( for the remote )
    sounds like you may only have the one module and are reading it that it does all.
    sorry if im wrong, just trying to get to the bottom of it with ya.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I have noticed people saying that closure of the roof was not available on the B7. Is this correct or do i need to get audi to do something that VSDS wont do ??
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Quote Originally Posted by 1wheelonly View Post
    Ah you could be right then. I take it i need the 2 modules to use it from the remote
    I only have the one that fits in the back quarter. TBH it was a bit of a gamble, there was 1 for sale on ebay to fit an A3 cab for 75.
    I went onto the web & sussed out they were the same unit so that was a result. You may be correct that i need the othe unit as well although i,m not that arsed about remote closure i just wanted the feature of being able to travel forward whilst the roof was going up.
    Thanks for coming back to give some help appreciated
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    yeh, deffo 2 modules, one touch is in rear quater and remote is in drivers door.
    i find the remote one better to be honest, never touched the button since fitting it .
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I suppose i need to order one of those then. Seeing as the other was next to **** all its not turned out too bad.
    Cheers for that i,ll get it on order, then it might work. FFS there is always summat amiss
    Feb 2011
    Rhubarb Triangle Yorkshire
    14
    Hi I have it on my 2011MY TT no probs
    On mine you press the unlock button 3 times to open or press the lock button 3 times to close
    If you press it 4 it doesn't work as any button press after the 3 is emergency stop ie you have just seen some thing on rear parcel shelf hope that helps and all you had wrong was the key press I only have one module in the car
    Jun 2011
    Nottingham.
    Ivor...
    Do you still have the fitting instructions? Need some TT specific quite urgently.
    Audi TT 8J Roadster....
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    If you google the instructions for a TT you will be able to download them. I did when searching for some A4 ones
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    as above you need to press the remote open 3 times
    its a safeguard so you dont accidently open it and not realise
    iv fitted them to b6 b7 tt a3 etc and iv never fitted 2 moduals
    always 1 in the back quarter
    also you keep refering to the mirror switches ?
