I'm after getting some lowering springs for my 2.0 tdi s line avant . I don't want to spend a fortune but want to retain the sporty feel it has already just lower by about 30-40 mm . What have people used and there thoughts / cost please .
Be prepared to be shocked at fitting costs. B7 suspension is not easy to work with.... just ask one of the guys at Awesome gti when they worked on my old B7 saloon.
You may struggle to get a 40mm drop over S-Line as they're already around 15mm lower.
A good choice could be the Eibach Sportlines which would give you another 35mm front and 25mm rear.
Eibach 50mm/40mm Sportline Lowering Suspension Springs A4 B7 Avant 1.9TDi, 2.0TDi, 2.0T FSi, 2.7TDi, 3.2 V6 FWD 01/05> - £135.65 : The premiere online mail order VAG suspension and performance specialists. We offer a wide range of all the best brande
If you wanted a more level stance, KW do a 50mm all round which would give you another 35mm.
KW 50mm Lowering Suspension Springs A4 B7 Avant 1.9TDi, 2.0T FSi, 2.0TDi, 3.2 V6 FWD 01/05> - £205.60 : The premiere online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performanc
Damian @ DPM Performance
Well you need your eyes tested, its 20mm lower.
There is more to it than just lower though, the progressive wound springs have transformed the ride, the Standard Audi stuff is pretty harsh / crashy. Now its miles more supple, but when giving it stick and loading up the springs the progressive wind means its nice and stiff in the corners, coupled with the RS4 ARB the handling has been vastly improved.
STD Ride pictured below.
HR -45mm Lowering springs on My 2.0 TFSI S-line Avant Quattro
