Badger5AH Fabrications
Results 1 to 10 of 10
    steve123a's Avatar
    Nov 2006
    London
    237
    TFSI Help Please
    I have been having a bit of trouble with my 2.0 Tfsi, It started to stutter a bit under full load and has been in and out of the garage for the past month and a half. It has had all the usual things checked and also just had a service.
    Firstly they have tested it and run the faults through the computer and gradually they have gone down from 7 faults to 3 faults, the last thing replaced was the maf sensor, which seemed to help for a short while and now it's back to as it was before with the engine management light back on.
    The garage have been very good in trying to sort the problem out, but even they are struggling to work out what's wrong with it, the fault codes now seem to indicate a vacuum problem and when the car is idling and you take the oil filler cap off, there is a real sucking vacuum noise and the car starts to almost cut out.
    If anyone can have a check on their car with the same engine and see if they get the same result I would really appreciate it? Or if anyone has any suggestions.
    Many Thanks Steve
    2002 Silver S3 225bhp SOLD
    1995 Cavalier Turbo 4x4 - 265bhp
    AUDI A4 DTM - Silver
    Mar 2009
    589
    Sounds like a PCV (pressure control valve) fault mate or possible coil packs ?
    steve123a's Avatar
    Nov 2006
    London
    237
    I have changed that twice now, once earlier on and again today just incase there was an issue it
    steve123a's Avatar
    Nov 2006
    London
    237
    The garage also changed the coil packs, didn't make any difference.
    Mar 2009
    589
    Er dont know then sorry mate try taking it to a specialist vag tech / awsome gti depends were your based ?
    Has it been back to Audi what do they say ?
    steve123a's Avatar
    Nov 2006
    London
    237
    It's in an audi specialist at the moment, does your car have the same engine? if so could you check if you get a vacuum when you open the oil filler at idle?
    Mar 2009
    589
    Ye same engine will check tonight for you mate !
    Jan 2004
    York
    1,657
    Which specialist ? Some are more "special" than others....
    MY15 8V S3 Sportback with options
    Jul 2006
    324
    sounds like a breather pipe problem,check the crankcase vent system for a blockage.
    Jul 2009
    London
    60
    steve, how many miles has your DTM done?
    A4 DTM Revo 2, Miltek turbo back, RS4 ARB, Forge dv. 290 bhp on a cold day!
