JMB RetrofitsVolks Autos
    Jul 2007
    33
    HELP DECAT ON A4 B7 140PD
    WANT TO NOW IF A DECAT IS A GOOD IDEA ON A 2.0 TDI WAS TOLD BY ONE TUNER THAT ITS NOT, REQUIRES BACK PRESSURE TURBO WOULD OVER SPOOL I DID COFIRM THAT IT WAS A 16 VALVE DIESEL, AND ANOTHER WELL KNOWN TUNER SAID IT WOULD WORK WELL A GOOD IDEA,
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    If a petrol turbo engine is anything to go by then both are correct. If you just decat it your turbo will over spool as there is no longer the restriction in the exhaust that it is mapped for. If you decat it then have it mapped the tuner will map it for a decatted exhaust so it will not over spool.
    More power safely and better fuel. Again this is all based on a petrol turbo engine so you'll have to check with maybe AMD or somewhere similar.
    Hope this helps buddy?
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    Jul 2007
    33
    THANK, FOR YOU HELP I GUESS I'LL GIVE AMD A CALL AND SOME OTHERS AND TAKE IT FROM THERE,WHAT MADE ME QUESTION IT IS I COULD NOT LOCATE A DECAT PIPE FOR THIS MODEL2.0TDI BUT LOCATED DECAT PIPE FOR THE 1.9TDI B6 MODEL WHICH APPEAR'S IDENTICAL
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    The 1.9 is a completely different engine so although it appears to be identical I doubt it will be however I don't know that for sure so don't take my word for it, just voicing my opinion in the hope that it helps!'
