Sky InsuranceVolks Autos
Results 1 to 14 of 14
    14
    Rear window won't go all the way down on my Cab??
    My rear window won't go all the way down on my B7 Cabriolet 2.0tfsi. Still has about 5 inches more to go.
    As it hits bottom it is as if it thinks it is actually at the bottom, or in other words it isn't snagging and the motor isn't try to repeatedly come down.
    Any idea guys?
    Adam
    Jun 2007
    131
    Hi
    If its the same as the saloon I dont think its meant to go all the way down...some safety reason I think
    HTH
    JohnyT
    North Wales
    39
    My 08 cab windows go all the way down but alas I can't help you resolve your issue.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Perhaps its hitting a speaker cable ...Mine go all the way.
    Perhaps it may need a vag . com check
    Jul 2010
    Berkshire
    Mine has done exactly the same today. Does anyone have any ideas?
    Jul 2010
    Berkshire
    About to strip mine down unless someone can help.
    14
    Quote Originally Posted by HARRIM00 View Post
    How did you get on with the strip down Harrimo?
    Jul 2010
    Berkshire
    Stipped it down, nothing out of place, greased and lubed, nothing. Think it is the regulatory. Tried various resets, none worked. Big job to do the reg, glad I've got a warrantee.
    14
    Keep me informed on this Harrimoo
    14
    What resets have you tried Harrimoo, I could give that a go.
    14
    As an update to this thread my window has now started working as it should, how odd! All is now good.
    007
    Oct 2010
    London
    11
    My driver side rear window on my 2007 a4 cabriolet is doing the same thing all of a sudden. Did anyone find a fix?
    Sep 2011
    Worcs
    57
    My 06 drivers rear window also started the same trick, won't go down the last 6 inches.
    Is there a reset procedure ?
    A4 B7 3.2 Quattro Cab
    Jan 2007
    Berkshire
    40
    Quote Originally Posted by vanbling View Post
    Any idea guys?
    Adam
    Hi,
    Same thing happened to my wife's car today. Also a B7 Convertible 2.0TFSI. To fix, 1. ensure all windows are up. 2. Unplug the battery for the car. 3. Leave for at least ten minutes. 4. Re-connect battery. 5. Open and close each window fully. Hey presto....it works. The rear window opens fully. 6. Reset your car's date/time and also sync your keyfob with the car again.
    Good luck!
    Bebecheekyfamily!!!
