Results 1 to 12 of 12
    Jul 2010
    99
    Brake warning light woes!!!
    I know this problems have cropped up in various forms but I can't find a problem like mine . Basically my large brake warning light comes on and flashes and beeps 3 times but not that often and not generally when cold but from time to time when engine is at running temp and sometimes when cold but only now and again. It doesn't seem lazy on startup and the fluid is full and all pads are fine and new on front.the old front ones were worn past the sensors and I don't know if I needed to reset anything? But I can't think what else it is brakes are working fine.
    Jun 2010
    Glasgow
    Only when starting?. Had this issue a few times and there is a known fix for it. Its due to the current draw during starting affecting the level sensor and involves fitting a relay on to the sensor signal wire to dash panel which disconnects it under cranking.
    Jul 2010
    99
    Cheers , is that a main dealer only job plus any idear of the cost. Cheers
    Jun 2010
    Glasgow
    If your handy with wiring then its a 10min job. Its only a relay so wont cost much. Is it still under warranty?
    Jul 2010
    99
    No mate but if I knew exactly where it went I could get it done.
    Jun 2010
    Glasgow
    il give you a diagram if you want. Just to confirm.. When your cranking the engine.. the red brake warning light iluminates?. Just dont wanna give you a fix and turns out not to be that. PM me your email. Cheers
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Quote Originally Posted by GAudiTech View Post
    Could you PM me the fix too please.
    Jun 2010
    Glasgow
    Email sent..
    Jul 2010
    99
    Thanks mate I've printed it off but I will defo have to get someone to do it . Thanks again though. I will do a search to see if somevone is near to me that can do the job
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    i have this problem on a 99 S4, i read today that if your battery is on its way out it will cause this problem due to the voltage drop when cranking the engine. Would a battery test show the battery performance dropping and would a new battery resolve it? My problem only started when i'd been away working and had to charge the battery when i got home it never felt 100% for a while when starting but seems fine now
    Aug 2010
    have the same problem. red brake light iluminates when cranking. i would appreciate a diagram for fitting relay. cheers
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    it is true about the battery because it did the brake warning light on mine a few times not long before the battery died, new battery fitted and i have,nt seen the warning light since.
