AH FabricationsJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 67 of 67
  1. #41
    27,097
    Ah you have a B8,sorry I missed that part.
    Post in the B8 section please.
  3. #42
    Mar 2010
    33
    Ok thanks. I think I did post there before but no one responded
  4. #43
    27,097
    Sorry mate but B8 is fairly new tbh & alot come well spec'd so not modded as much on the technology side.
  5. #44
    Mar 2010
    33
    Oh ok. I have posted in the B8 section
  6. #45
    Sep 2009
    Huddersfield
    106
    Sorry to invade this thread - but can anyone help me?
    I'm just about to buy the item in the e-bay link above
    (http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_2829wt_1001)
    AUDI Bluetooth KIT - RNS-E A4 8E0 A3 TT A6 UHV RNS BNS
    Does anyone know who would fit it for me - I live in Huddersfield, West Yorkshire.
    Thanks,
    Tim.
  7. #46
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    listing has been removed.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
  8. #47
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    F
  9. #48
    Sep 2009
    Huddersfield
    106
    Sorry - yes that's the one (I've just had an offer of Ł190 all in, accepted).
    Don't want to buy until I know someone who can fit it though.
    Thanks,
  10. #49
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Good price, can't help you with fitting 1wheelonly fitted mine, i sure someone in your area will be along soon, or a local audio installer will do it, what head unit have you got.
    F
  11. #50
    27,097
    Quote Originally Posted by Fireyjack View Post
    I can arrange fitment.
  12. #51
    Sep 2009
    Huddersfield
    106
    RMH1A4CAB - I have a Concert II unit and MFSW.
    NHN - where are you located? any idea on a price?
    Thanks,
    Tim.
  13. #52
    27,097
    Work all over mate, if you need work done please PM me for further info thanks.
  14. #53
    Oct 2010
    17
    Hi Folks
    Sorry about hijacking this thread. Looking for some advice. I bought one of these the other week and am having issues with it . I installed it in a 07 A4 S-Line 2.0 TDI with Concert II Radio . I bought one of the BT systems advertised in this thread (Audi OEM Kit)
    On install, the Speak button on the steering wheel worked and we could place calls straight away but it would not pull any contacts from my address book . Also the Mode button is not doing anything. It previously said NO FUNCTION when pressed but now, nothing .
    I brought the car to a car audio shop and they hooked up via VCDS and tried to query the telephone module (#77) it comes back Not Available .
    Any ideas ? The guy in the shop was not familiar with the kit but as far as he is aware he was going into the correct module settings page ..
    Cheers in advance
    Martin
  15. #54
    27,097
    Did you connect the Kline wires as iirc the B6/7 arent canbus, this would be the comms issue I reckon, then once you can connect, you can code it correctly so other functions work, although the best head unit to use with the BT setup is definitely the RNS-E as it will display a hell of alot more info.
  16. #55
    Oct 2010
    17
    Hi , thanks for the response.
    I will need to check this in the morning , also I just checked and my A4 is the 8E model , just had a look at the chassis number . Will that make a difference ?
  17. #56
    Oct 2010
    Hampshire
    36
    First of all sorry for the hijack. Please move the thread if you feel it warrants it.
    I have just bought an used A3 Sportback black edition from an Audi Dealership. Part of the deal I struck with the dealership was to have an Audi Bluetooth kit installed. Audi arranged for a third party installer to fit this today at my work as they didn't have time to do it before I collected the car (a week wasn't long enough apparantly). The installer fitted a Fiscon kit despite me asking if it was definately a proper OEM kit. Unfortunately I didn't find this out until I came back out of work when he called me to say he'd finished.
    Now to begin with I was a bit annoyed that after stressing several times to both Audi when I was buying the car and the installer when he arrived that I wanted the OEM kit I've had the FISCON kit installed. I was more annoyed that when I scroll through my contacts I get multiple entries per contact in the DIS - one for each of the phone numbers they have. However there is no way of telling which number is which. Can anyone confirm you can tell which number you are about to call? i.e. if I have a contact John Smith with home number, mobile, work, fax I can call John Smith - Mobile. At the moment I just get 4 John Smiths in the DIS! Please tell me the Audi kit is a bit smarter than this!!!
    The final straw was on driving home tonight from work. I now have a whistle related to engine speed when the radio is on (even on but muted). It's not really loud but it's there and annoys me. One of the reasons I chose the car was as it had BOSE. Now I have a crystal clear whine through lots of speakers. It didn't do it before, any chance that if I swap the FISCON for the Audi OEM kit my problems will all be fixed?
    Thanks for reading my rant!
  18. #57
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Please , don't talk to me about bluetooth i'm having a nightmare with mine Ł220 out of pocket and still no bluetooth .
    Kaedo i hope you get yours sorted soon .
    F
  19. #58
    Oct 2010
    Hampshire
    36
    Quote Originally Posted by RMH1A4cab View Post
    Sorry to hear you're having issues. How far have you got. I assume you've bought the unit and fitted it but it's not working?
    I've moved my post above to the A3 forum but will keep checking both.
    Thanks,
  20. #59
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    Quote Originally Posted by kaedo View Post
    The Audi one is better than that mate
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
  21. #60
    Jan 2004
    York
    1,657
    I have FISCON with bose and have none of the issues. Sounds like your installer has made a balls up with the install.
    kaedo....
    What phone are you using with the kit regards the multi number issue. My Iphone 3gs on OS4.1 doesn't have this issue.
    MY15 8V S3 Sportback with options
  22. #61
    Oct 2010
    Hampshire
    36
    Hi, it's a Blackberry Curve 8520 on Orange. It's a work phone and syncs with all the contacts in Outlook including shared contacts (everyone in the business).
  23. #62
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Thanks,
    Long story short, i had an audi oem bluetooth unit installed by another member off here worked perfect for a week then i started to have issues after alot of scratching heads it was diagnosed as a faulty unit.
    Contacted the seller in poland who said send it back, six weeks later they said it never arrived dont know if they are telling the truth or not.
    Royal mail international signed for delivery with insurance is not worth the paper it written on , got trading standards involved now , nightmare .
    So out of pocked and no bluetooth to say i'm pi**ed of is an understatement .
    I think your is bad fitting so i would get them back , hope you get it sorted soon .
    F
  24. #63
    May 2007
    Chorley, Lancs
    781
    I fitted the "Q" i.e. 2007, version of the OEM Bluetooth (BT) module to my B6 with my RNS-e Head unit. It worked brilliantly with my "old" Nokia Phones. Last March (2010) I upgraded to a Nokia X6.....although I can pair the X6 phone to my Audi BT, I cannot upload the address book.......all Nokia could advise is that I need to change my Audi BT module for a newer one - yeah right at Ł250 do they think I came down with the last shower of rain....
    My tip is get a Parrott BT which can be very easily upgraded via internet & your PC - all for around Ł120
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
  25. #64
    Jan 2004
    York
    1,657
    The fiscon unit is parrot based with a canbus interface. So best of both worlds.
  26. #65
    gynads's Avatar
    Oct 2009
    338
    Where abouts are you based please NHN?
  27. #66
    27,097
    why whats on your mind fella?
  28. #67
    jon-easy's Avatar
    Nov 2010
    27
    Hope you don't mind me posting here, but does anyone have experience of a Dension Gateway 5, which apparently does Bluetooth and iPod integration? I have a Concert II. Thanks
Tags for this Thread
