DPMAdrian S Flux
    barters3's Avatar
    May 2008
    440
    Post Thanks / Like
    s3 8l 2001 aircon leak
    My brother is an ac engineer and he carried out a leak test on my ac. there is a howler of a leak which is situated behind the rigid heat insulation between the turbo and the main bulkhead.
    I dont actually know where the leak is coming from. I just want to establish whether there are any components in this area that leak. Access is very limited and at best i would imagine the boost pipe etc would need removing.
    Any advice would be much apreciated.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    You may have more luck in the 8L section (if you haven't tried already) as I don't know anything about them.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
