KowalskiW8 Performance
    20
    Post Thanks / Like
    Air con cleaning help
    Hi peeps,
    My air con smells like cat wee when in use and the pollen filter housing also smells. I've read the threads already posted and gone out and bought some comma air-con cleaner and a new pollen filter. Would it be best for me to clean the pollen filter housing and change the pollen filter before using the comma spray or vice versa? Also should i just set the air-con to re-circulate on full cold (lo) setting or use the econ setting? Any help much appreciated.
    Ian.
    denzelburner's Avatar
    Sep 2007
    Devon
    166
    Post Thanks / Like
    Hi,
    TBH I'd clean out the housing and put the new filter in and try it like that first to see if it makes any difference. If it does, save the comma for another time, if not, use it.
    If you do use it, I kept the econ off, this worked a treat on mine.
    If you can't beat them, arrange to have them beaten
    2000 B5 2.5tdi V6 (if only it were a quattro)
    20
    Post Thanks / Like
    Hi ,
    Thanks for that will give it a go, hopefully today. Good idea about trying it without the comma stuff first :-).
    Ian.
