DNA TuningGNJ
Results 1 to 7 of 7
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    773
    Post Thanks / Like
    Any A/C guru's on here?
    Hi all.
    Is there anyone on here who's pretty switched on with car A/C?
    Just after some advice.
    The problem i have is, when i start the car on a cold morning i get a whine from the a/c compressor for around 20 seconds.
    If i start the car with the a/c off its fine.
    Also, the aux belt and tensioner are new..so can rule them out.
    I have tried a re-gas to the specified 750g... which didnt change anything.
    Have also tried running with 700 and 680g of refrigerant in the system, to hopefully take some load off the compressor.
    Neither changed the noise.
    (whilst at it i dumped 25g of PAG in there to help lubricate the system)
    Now im stuck for idea's short of renewing the compressor.
    What usually takes the wear?.. is it a bearing or the clutch?.
    Any help appreciated.
    Good 2 B A Gooner's Avatar
    Jesus wears a number 4 shirt..
    May 2009
    Chichester
    713
    Post Thanks / Like
    Quote Originally Posted by csweatherston View Post
    Hi all.
    Can't remember his Username - but if you read through this and the General Chat links, you'll see a guy who's signature has feq asked Q's on A/C
    Present - 2005 - A4 2.0 TDI S-Line Past - 2001 - A3 1.8T Sport Past - 1997 - VW Golf GTI 8v
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,978
    Post Thanks / Like
    You're thinking of Staz.....
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    773
    Post Thanks / Like
    Cheers guys, ill drop him a PM.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Hello mate,
    to be fair it's more a mechanical problem than an air con one. The PAG is used to lube to seals in the pipes and the compressor internals so I'm not surprised that it didn't solve the problem as it does sound more like it's down to the external parts. If you've changed the tensioner and the belt (and they're fitted correctly) then I'd suggest it's the compressor pulley bearings.
    I'm no guru by the way. I did an ECS course in 2007 and haven't used it since so please don't take anything I say as gospel, I'll help if I can though
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    MrCSW's Avatar
    Hulk Smash!
    Sep 2009
    773
    Post Thanks / Like
    Ahh, cheers for the reply Staz.
    Im pretty sure its the compressor pully bearing/s.... Are these servicable?
    My Other option is to dump the gas out, so the ac clutch wont come in....hmm
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Well you can disable the clutch by removing the fuse/disconnecting the connector anyway mate if that's all you want to do. I'd have thought you'd need a new compressor if it's the bearings but I don't know. It'd probably be almost as cheap to get a reconditioned compressor anyway, plus you'd get a warranty on it.
