DNA TuningUnicorn
Results 1 to 20 of 20
    LordNelson's Avatar
    Aug 2009
    167
    Post Thanks / Like
    Pressure Switch Location?????
    Can anyone help my locate the Air-con pressure switch on my S3 8L (2000).
    I might be being stupid but cant locate it.
    I need to test the switch before i go and buy a new one.
    thanks
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    You may have more luck in the 8L forum mate.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    mike-turbo's Avatar
    Sep 2009
    42
    Post Thanks / Like
    its behind the heat sheild at the back of the turbo
    technics100's Avatar
    Feb 2004
    Co Antrim
    766
    Post Thanks / Like
    On the A4's the pressure switch is located on the air-con radiator near the pass side headlight, its just a unscrew and change job..
    2003 Silver A2 1.4 TDi - 65mpg & £30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Oct 2009
    Post Thanks / Like
    Does the system need the gas removing first? My A4 has a blown fuse 6 (air con pressure switch) and blows a new fuse as soon as the ignition is swiched on. I'm thinking that if the wiring is ok (will test for a dead short at the plug when I find the damn switch) then the pressure switch must have died and gone dead short.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Yes mate if you want to change the pressure switch the whole system needs to be recovered
    Oct 2009
    Post Thanks / Like
    How the hell can you get to the sensor? Please tell me you don't have to remove the front bumper!!
    2005 Audi A4 Avant 1.9TDi
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    You may have more luck asking in the A4 forum mate.
    Feb 2004
    Co Antrim
    766
    Post Thanks / Like
    Quote Originally Posted by Wobbler View Post
    No it doesn't (B6 A4) it just unscrews and unplugs..
    18,275
    Post Thanks / Like
    Quote Originally Posted by mike-turbo View Post
    Yeah this is where it is I believe, as thats what I had to change on my late 99 S3 once, I lost cold air, so changed this which was £50 & it worked again, its slightly more to the right IIRC from the turbo, but is hidden behind the heat shielding in that area attached to the silver pipes & as already said, they emptied system then regassed to do the job.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Quote Originally Posted by technics100 View Post
    Ok if you do it that way you'll vent all the refrigerant!
    18,275
    Post Thanks / Like
    I would have to agree, given the name of the actual switch it would suggest its not a good idea to undo it without removing the pressure it reads, given its refridgerant that wouldnt be wise huh Staz.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    ...and illegal!
    Plus it would allow air into the system if it was done that way so it'd have to be deep vacuumed before recharging.
    Oct 2009
    Post Thanks / Like
    I have read that the switch screws into a valve assembly similar to a tyre valve, although this would mean some gas would escape as the valve was removed/fitted.
    Think I'll get the garage to do it for me.
    18,275
    Post Thanks / Like
    Advisable mate, given the system involved & yes, iirc, it just screws onto the pipe as such.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Yeah and as the refrigerant escapes it super cools and will give you frostbite.
    Oct 2009
    Post Thanks / Like
    Sooo. gloves would be advisable then?.......just kidding, given that the bumper has to come off and that I have no inclination to undertake a job I'm unsure of, I'm gonna book it into the dealers.
    18,275
    Post Thanks / Like
    Why take it to a dealer mate, take it to any garage that has an ac gasser, they can remove the bumper & re-gas for a hell of alot cheaper than audi for sure.
    Feb 2004
    Co Antrim
    766
    Post Thanks / Like
    Changing the G65 pressure switch does not vent the system. I have changed the sensor, it just unscrews and the new one screws in.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    How does it keep the refrigerant in then?
