Sky InsuranceBadger5
Results 1 to 7 of 7
Thread: Stumped
    Sep 2009
    36
    Post Thanks / Like
    Stumped
    right had my aircon recharged today all is fine however zero cold air mechanic sayed i should hear a click when i push the aircon button but zero click so should i replace the relay???? if so where is it located
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Relay?? The click should be in the engine bay and it's the electromagnetic clutch not a relay. Have a read of the FAQs thread for more info.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    Post Thanks / Like
    if it has too much or too little gas in the system the compressor wont kick in either but i do hear a relay click in the fuse box when i switch mine on
    Sep 2009
    36
    Post Thanks / Like
    Right had a look in the engine bay and nothing seems to go on when the air-con is switched on???? also if i push the recirc button the aircon switches on ie i get the snowflake on the display.....any body any ideas??? oh and leon only said relay as thats what the garage said they never heard a click when they switch it on
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,978
    Post Thanks / Like
    Similar problem in THIS thread, but no answer for you yet I'm afraid.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Sep 2009
    36
    Post Thanks / Like
    going to check these not sure if it will tell me what i need to know but hay any body know what values i should see ref the A/C clutch voltage etc ie if the compresser is fubar it should be zero its its working should be 12ish
    http://www.audi-sport.net/vb/showthread.php?p=749487
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    I'm not sure I understand the question mate. I you can check the clutch voltage when the air con is enabled then do it!
