Stumped
boyrollo
NULL
right had my aircon recharged today all is fine however zero cold air mechanic sayed i should hear a click when i push the aircon button but zero click so should i replace the relay???? if so where is it located
Relay?? The click should be in the engine bay and it's the electromagnetic clutch not a relay. Have a read of the FAQs thread for more info.
if it has too much or too little gas in the system the compressor wont kick in either but i do hear a relay click in the fuse box when i switch mine on
Right had a look in the engine bay and nothing seems to go on when the air-con is switched on???? also if i push the recirc button the aircon switches on ie i get the snowflake on the display.....any body any ideas??? oh and leon only said relay as thats what the garage said they never heard a click when they switch it on
I'm not sure I understand the question mate. I you can check the clutch voltage when the air con is enabled then do it!
