psychochild187
car is a 1.8 t quattro on a t plate
the story is ,.
air con compressor bearing was shot and so was the tensioner
replaced parts from a donnor compresor the magnet,clutch bearing part and clutch face all different slightly becacuse the other compressor had a different shaft lenght.
same part number but the letter at the end was different
the pipe from compressor was bend/scrapeed so this was replaced as the system was open and then because it was so hard to get off it took out the condenssor too
i also replaced the filter air dryer 10 mins before the system was regased to the correct amount by my amazing local air con guy ( who owns 2 quattros himself mr klaus ward 07973252531) brighton ish area!!
the problem is although we had it working fine when klaus regased it . and the morning after it blew the fuse to the blower
called gsf and orderd a fan and replaced this . becaus eit was blowing the fuse with the engine off and the fan sounded lazy
then it worked fine .
next day after more use it blew again .
now the thing i am hoping it is .. is the compressor clutch plate is of the wrong type and no 100% straight it does engage and does sit tight .
but there are some gaps but not much
i cleaned the faced up and bent it and played with it today to strighten it up to sit flat but its almost impossible and after 30 mins of it running on the car messing about with air con settings . pop! it blew again ..
why can it work for a while then pop .
should it not work or work . i just dont get why its lasting long enough for me to think its done and fixed and crack ! it blows another 30a fuse
do i need to order a new clutch face that is straight 100% or look elsewhere for wirering etc?
before i reduce the number of quattros in england and increase recycled steel in china
the story is ,.
