JMB RetrofitsChris Nott
    Dec 2006
    barnsley
    1,016
    audi air con compressor
    can anyone who is clued up about air conditioning on cars please be able to help me with information
    how fast does the average air con pump spin at ???
    is it possible to drive one off a 12 volt motor instead of off the engine directly ??? a lot of the more modern french cars now use electric air con as standard
    if so does the pump and compressor have to spin at a certain speed to move the fluid round to get the cooling effect ???
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Apr 2013
    Aberdeenshire
    592
    Hi I am a refrigeration & air con engineer is possible to run a compressor electrically however you would likely have retain the clutch as the high torque required to start the compressor would draw a high current on battery's
    also minimum speed is not to critical as many commercial compressors are are inverter driven especially in air conditioning for capacity control and energy efficiency although the faster they run the higher the capacity .
    belt driven automotive compressors use a modulating valve to regulate compressor capacity based on suction pressure.
    a compressor compresses vapour from the suction to a high pressure gas known as discharge it is then cooled from a hot gas condensing it to a liquid for your expansion device of any type be it a valve or capillary .
    hope this helps
    Apr 2013
    Aberdeenshire
    592
    [QUOTE=Chillout;1977089]Hi I am a refrigeration & air con engineer is possible to run a compressor electrically however you would likely have retain the clutch as the high torque required to start the compressor would draw a high current on battery's
    That said as electric cars run off higher voltages they must have developed a hermetic compressor for the electric market making the shaft seal redundant.
    Dec 2006
    barnsley
    1,016
    the reason i ask is i would like to convert my air con from shaft driven (s4 v8 )to electrically driven
    so basically as long as i can find a motor which has enough torque to turn the compressor on the input shaft then i should get cold air con
    the only other problem i have is its that tight a space down there i need to put the motor and shaft through a ninety degree gearbox
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by dualmono21 View Post
    Why do you want to drive it electrically ? As any electrical load will increase the load on the alternator and In turn the load on your engine to turn it ,it's probably not much different
    you will only loose a few bhp to run your a/c that I would think would go un noticed on your lump.
  1. Audi a4 air con compressor
    By Ashpotter1991 in forum Parts Requests
    Last Post: 19th July 2012, 20:51
  2. Audi TT Air Con Compressor - 1J0 820 803 K
    By mikem1 in forum For Sale/Wanted - Audi Parts
    Last Post: 5th July 2012, 12:09
  3. Audi S3/A3 2.0TFSI Air Con Compressor (N280)
    By TimJK in forum For Sale/Wanted - Audi Parts
    Last Post: 19th January 2012, 21:51
  4. Air Con Compressor
    By Tiger6791 in forum General Technical / How To
    Last Post: 19th October 2004, 21:47
  5. Air Con Compressor
    By Tiger6791 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th October 2004, 21:56
