Volks AutosSky Insurance
Thread: G65 wiring test
    whinfs's Avatar
    May 2013
    Barnsley, UK
    35
    G65 wiring test
    Evening
    ECON light permanently on. I went to have my a/c regassed at a local auto elec. he informed me there was a fault with the pressure sensor and i would have to return another day to leave the car to have the wiring to the sensor checked, new sensor fitted and regassed for £200. ouch.
    ive got a multimeter - can i unplug the sensor and see what voltages are present? if so should the engine be running and what voltages should be there?
    i really cant afford £200....
    cheers
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by whinfs View Post
    Evening
    cheers
    Your sensor should just unscrew and the schrader valve core should hold the charge unless the core has been removed or leaks
    unscrew it very slowly you will get a little hiss but it should stop before it runs out of threads.
    whinfs's Avatar
    May 2013
    Barnsley, UK
    35
    thanks for the reply. i plan on doing that but it was wondering can i test the electrical side i.e. the plug to make sure voltages are there
    Apr 2013
    Aberdeenshire
    592
    Yes it can be done terminal 1 is at the square end it is the ground/negative terminal 2 is in the middle and sends a square wave to the ecu that can be measured with a scope terminal 3 is the positive round end
    i would assume it is faulty if your system is not choked or overcharged hope this helps.
  1. Top Gear road test PDF files for S3?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2003, 12:13
  2. Test Drove New A3
    By dbm in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 23:21
  3. TTC180 road test results anyone?
    By Mikiew in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd June 2003, 20:51
  4. Tested ... 220km/h for A3 2.0 TDi
    By roberto in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2003, 04:58
