    Sportback owner
    Apr 2007
    France
    465
    Climate control strange behaviour
    When I start the car, the climate control does not seem to work. However, after a few minutes, it suddenly wakes up and produces lots of cold air. I had it re-gassed today, and when the mechanic had finished he tried to measure the temperature of the air, but again it did not produce any cooling. Then after about five minutes of tick over, the climate control fans started up and again plenty of cold air. I have no chance to do a VCDS scan at the moment. Just hoping someone would suggest what may be wrong. The mechanic thought it might be a temperature sensor. Any suggestions very welcome. Thanks in advance.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,414
    I get this sometimes also and curious to a cure.
    I find that if I sometimes turn the engine of and then on again it is fine, which makes me think it is the blower power module
    Mike
    Sportback owner
    Apr 2007
    France
    465
    Thanks Mike. The car blower seems to be working, but I will watch it like a hawk. So far, the climate control system seems to be working as I would expect. So maybe (I hope) the system has somehow reset itself. I will have a chance of doing a VCDS scan in mid July. So will try to be patient and then see if there are any fault codes showing up.
  1. Climate Control Problem
    By adjturbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th December 2003, 21:38
  2. What's up with Audi climate control?
    By redaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2003, 14:43
  3. Audi A3 Climate Control
    By ramstein666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 20:18
  4. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
  5. Retrofit LCD climate control
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 11:42
