Volks AutosAH Fabrications
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    521
    My poor old A4's not as cool as it used to be!
    I know very little about air conditioning systems, so here goes.
    Car is a 2003 1.9 TDI B6 A4 with the standard 2 zone climate control.
    It's had a problem for over a year now really. On moderate days (15-20 degress) after sitting for a day in the sun, I get in and open the windows to let the hot air out. I turn on air con to 21 and leave it. Fan speed will go to 1 or 2 bars and stay there for about 3min, pumping out cool air. Then after that the fan speed goes to 4-6 and pumps out cool (not cold) air. So all is fine, despite it not doing what it should.
    On a hotter day, or if I put the air con on LO, the fans go crazy and just pump out ambient air.
    So that's the problem. It was recharged a year ago (professionally) and there are no fault codes stored.
    Does anyone have any ideas what the problem is? It strikes me as a problem with wear somewhere in the system - because it works when running at low speed, but not faster.
    Any ideas gratefully received!
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by benjie View Post
    hi the faster your vent fans run the more load placed on your a/c it sounds like a capacity issue when your fans are running flat out if you check your suction pipe (largest pipe from the cabin to the compressor) should have condensation/sweat on it that is a good sign it is fully charged your condenser / radiator fans should also be cycling on and off
  1. Replies: 5
    Last Post: 28th February 2011, 19:16
  2. OMG this might old news but it's COOL
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2010, 10:08
  3. not even cool
    By will_maddox in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2010, 00:06
  4. POOR OLD S3
    By nick-barnes07 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2008, 22:52
  5. Steering not as tight as it used to be.
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2007, 10:24
