Volks AutosAH Fabrications
    Apr 2013
    Removing Radiator
    I am trying to remove the Air Con Rad from infront of the intercooler. What do i do with the hoses, blank them off? i won't have any problem will i?
    Jan 2013
    Moray
    228
    What car? Which hoses? Is your intercooler REALLY behind an aircon rad?!
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Apr 2013
    A3 2.0 TDI 140 DSG.
    Yes if you stand infront of car, it goes Air con rad first, Intercooler middle and coolant rad at back. Maybe it will help keep car cool as fans were constantly having to turn on.
  1. need help how to remove radiator upper flange
    By 1.8T_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2012, 09:42
  2. Cannot remove the quick coupling from the radiator bottom. A3, 2.0tdi
    By audio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 22:28
  3. Radiator removal 2.0 TDI
    By Cyrix in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 18:38
  4. Removing Radiator on Audi A3 1997
    By breneenio in forum General Technical / How To
    Last Post: 15th January 2010, 17:46
  5. radiator removal - uh ?
    By fergusd in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2007, 17:33
