Results 1 to 11 of 11
    glenandem's Avatar
    Sep 2012
    manchester
    451
    a/c inop, this sensor missing!
    hi guys after recently doing my cambelt i noticed that the sensor in the side of the rad was actually missing, now im thinking of getting a new one and getting it regassed to see if it will work after that but should there be a valve core in the middle of the hole where the sensor screws onto the side of the rad?
    Mar 2010
    Durham NE
    575
    are you on about the pressure sensor? got a pic? when you say rad do you mean ac condenser?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    glenandem's Avatar
    Sep 2012
    manchester
    451
    Here's pic pal,I've replaced this sensor on other cars in the past and they've had like a schrader type valve like on car wheels with the centre pin in and this looks like its missing?
    glenandem's Avatar
    Sep 2012
    manchester
    451
    Just bumping this up as its something I'm going to sort now the weather getting warmer, if anyone can help by letting me know if I should have a valve core in the centre if the hole where you screw the ac pressure sensor on would appreciatte it, cheers glen
    Apr 2013
    Aberdeenshire
    580
    I would expect it to have a core so the sensor can be replaced without the charge however since your a/c has been open to atmosphere you will need replace the switch then have it pressure tested ,compressor oil and the drier changed ,system evacuated and charged before you spend loads replace the sensor and have it pressure tested with ofn (oxygen free nitrogen) as you may have leaks on top of your missing switch.
    glenandem's Avatar
    Sep 2012
    manchester
    451
    hi mate after investigationive foundit should have a shrader type valve core so mines missing,not sure why?
    wondering if i can just put a valve core out of a innertube etc or whether theyre a special part or maybe i can just fit a new pressure sensor but will have to drain the system if it ever gets faulty?
    Apr 2013
    Aberdeenshire
    580
    Hi the cores are of the same construction however I think they are likely to be a different size I don't even think the cores I have are the correct size however core kits can be bought I will have a look to see what I can see , you could just by the switch and get the oil and drier changed and recharged as your system could have further issues
    glenandem's Avatar
    Sep 2012
    manchester
    451
    would really appreciatte that matey, i was dying today with this heat in the car!
    hopefully it will rain tomorrow lol
    Apr 2013
    Aberdeenshire
    580
    Found various kits via google but no guarantee they will fit when I was doing automotive a/c any parts I found faulty/damaged were replaced by the mechanics then re commissioned by me so I never replaced valve cores on a/c.
    glenandem's Avatar
    Sep 2012
    manchester
    451
    cheers pal,think im just gonna get a new g65 and o ring and fit it, if i ever need to remove the g65 i will have to get the system drained down as thats what the shraders there for i suppose so you dont have to drain the ac system!
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by glenandem View Post
    To be honest you can't really trust the cores not to pass I have had them stick when removing hp switches with 15 bar of liquid behind them as you unscrew them you allways have it on your mind that it might not hold or as your on the last thread it might be missing ,
    at least with car a/c R134 is at a relatively low quantity and pressure interested to hear how your system runs after being open to atmosphere for a while hopefully it run well.
  1. What is this sensor for and where does it go?! (pics)
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2011, 13:14
  2. Where is this sensor???
    By m444ty p in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2009, 16:28
  3. Where is this sensor ?
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2009, 23:44
  4. What does this sensor do? 8e0 959 651 b
    By Eddie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2009, 00:25
  5. whats this sensor/valve?
    By petewon in forum General Technical / How To
    Last Post: 10th April 2007, 16:55
