Chris NottAH Fabrications
    Lancaster
    1,780
    Audi A6 - Pressure good but no cold air
    Hi.
    We have a Audi A6 2002 1.9 TDI 130.
    When we got the car the ECON light was permantly on. I ran vcds and found a fault with the G65 sensor. Actually it'd been fully removed and the connection damaged. So I repaired the connection, fitted a brand new G65 sensor and had the system recharged.
    It then turned out that the clutch ( I say clutch but it doesn't have one as it has a N280 valve) was missing. So I got a new plate for it so it actually did drive the compressor.
    With VCDS I see a pressure increase with ECON being turned off and when I turn it on the pressure decreases. But I do not think the pressure goes up enough when the aircon is activated. My A4 goes to 9-12 bar when using aircon. Where the A6 barely hits 5 or 6.
    I have run the car for 3 minutes with aircon on, both sides on LO.
    I get:
    A/C Valve (N280) Current: 0.650amp
    A/C Valve (N280) Duty Cycle: 64.5%
    High Pressure Signal (G65): 19%
    Refridgerant Circuit Pressure (G65): 4.6Bar
    It seems low, but the actual pressure is fine.
    Could this be the N280 valve not opening enough to let the pressure build?
    To do: None yet.
    Lancaster
    1,780
    Well after the huge amount of suggestions.
    I did something I didn't want to, i bought a top up can. Charged it up and it's working perfectly.
    To do: None yet.
  1. Is this any good for cold air feed pipe??
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2011, 18:26
  2. Cold Air Intake on Audi A3 2.0 TDi
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2009, 11:59
  3. Audi S3 cold air intake.... ?
    By nadir in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2007, 05:38
  4. Survey on Cold Air Intakes for A4 1.8T's
    By imajn34 in forum Tuning
    Last Post: 26th December 2003, 13:08
  5. audi service....any good?
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 17:07
