EM TuningSky Insurance
    Nov 2011
    30
    Air con not blowing cold 8P2 S3 (possible N280 valve issue)
    Im having a bit trouble getting the air con to work on a 2007 S3 8P2.
    System has been leak checked and regassed without any issues. 'Econ' switches on and off ok (light goes on and off) and engine rev's adjust slightly in response, but still no cold air blowing.
    Ran a VCDS scan and no codes. Ran a VCDS log on the HVAC with the following results:
    0.700 A A/C Regulating Valve (N280)
    71.0 % A/C Regulating Valve (N280)
    22.5 % High Pressure Sensor (G65)
    6.0 bar Refrigerant Pressure
    0 Compress. Torque Signal Status
    5.0 Nm Compressor Torque
    0 A/C Compressor Regul.Valve (N280) after more than 15 shut off's the N280 is not being actuated by J255 anymore
    Im guessing a faulty N280 valve, which requires the compressor replacing.
    Anyone any other ideas??
    APAutomotive's Avatar
    Shark Performance Shropshire
    Mar 2012
    Telford, Shropshire
    81
    Switch air con on & have a look if the compressor clutch kicks in & works pulley.
    As long as no leaks & correct pressure in air con system, then when aircon switched on fan & compressor should kick in
  1. Air con not very cold and blows black foam from vents
    By bretto in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2012, 08:42
  2. Air con not cold.
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2010, 19:54
  3. Heating & Air Con not working
    By LeonardSkinner in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th October 2006, 21:11
  4. air-con not working
    By celica in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2005, 12:29
  5. '95 A4 Air Con not working
    By imported_Timbuk2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2004, 15:55
