Chris NottBadger5
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    Aircon not working A4 B8
    With the recent hot weather i decided to switch my aircon on,on Monday the light illuminated when i pressed the switch but the air didnt get any colder stayed the same as when the button was off and the temp turned to cold(LO).I have not used the car a great deal since October due to me rupturing my patella tendon and not being able to drive.When i have used the car over winter ive not had the air con on (hot or cold).Car is booked in at the dealers on Wednesday they tell me it may need re-gassing cost of £60 for this inc a air con service.Anyone had any experience if this or anything i can try or do before going to dealers or an yother issues that it could be?Car is still under warranty until September.
    2.0Tdi 170 Black Edtion Avant
    Apr 2012
    East Kilbride
    29
    Quote Originally Posted by redspudder View Post
    There could be a number of reasons for ur air con failing, u said the air can hadn't been on for a while, this can cause a problem as the oil needs to be circulated around the system and may have starved the compressor. The most Likly reason is that u have lost the charge in the system, there is no point in just getting it re-charged as u will lose it again. The source of the leak has to be found, repaired then re-charged and shoud be covered under warranty.
    Hope this helps
    Apr 2009
    Coventry
    2,219
    sounds like my air con when its working......hardly cool but 'within tolerances' im told.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Aug 2012
    6
    Hi Guy
    Recently i have a problem of air con of a4 b8 I hope someone can shed some light on the problem i am having, i don't know what to do next. The story so far.........I just purchased a 2004 A4 TDI Avant, the air con wasn't working when i brought it but i was assured it just needed a rages , this seemed plausible as the car had not been used for over a year. On the drive home i noticed the the Econ light would not turn off and assumed this was because the gas was low.
  1. Aircon not working
    By redspudder in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 4th April 2012, 18:07
  2. Aircon not working
    By waring192 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2010, 09:14
  3. Aircon not working on 97 A4 TDI
    By dubplate Dan in forum Air Conditioning
    Last Post: 11th August 2009, 17:33
  4. aircon not working
    By DJ-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2009, 18:54
  5. My aircon still isnt working
    By Nickynibbles in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2007, 11:47
