Results 1 to 8 of 8
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    air con clutch or control module fault???
    iv had no aircon since i purchased my a3 over a year ago
    when i switch the aircon on (econ off) the second fan at the rad comes on, but the clutch for the compressor does not come in
    i have got the plug off of the compressor and measured the voltage across it, it seems to be a constant 9 ish volts regardless of the air con being on or off, and when switched on the volts rise to 10v for moment and then back to 9v
    i have not been able to get to the connections on the compressor to check the coil (assuming there is one in there???)
    i dont get any vagcom faults when scanning the car relating to aircon, is there anything else i can check?
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Any one?
    1.8T SPORT AUM
    Progression Thread
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Please help me, I'm too hot =(
    1.8T SPORT AUM
    Progression Thread
    Mar 2012
    I have just the same problem but when i switch the econ button on ( air con off) my 9 volts go, the only thing switching the bair con on/off is this 9volts to the compressor if 9 volts isnt there it sont engage if it is there the clutch should engage. I have been looking on the internet and dont entertain the idea for a second hand compressor but the cheapest i have found is 210 + vat from a website called fastrads its a common problem with these cars and a/c pumps some audi garages deny it others tel you its very common, replace the compressor and it will solve all your troubles let us know how you get on
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    when i get chanve im going to make up a plug to chech the resistance through the coil in the clutch, then stick 12v up ity and see if it opperates,
    will probably be next week at the earliest
    1.8T SPORT AUM
    Progression Thread
    Sep 2011
    Lancashire
    9
    Yup i'm having the same problem i even ran a 12v supply seperately to the compressor it's self still no aircon nor does the clutch plate engage so it's looking like a new compressor also resistance is 10ohms where from what i've read it should be 3.6ohms
    To advertise on site, please contact admin.
    Lancaster
    1,780
    Have you tried a new clutch relay?
    To do: None yet.
    nddy's Avatar
    Dec 2012
    compressor clutch
    I am experiencing a similar issue my a4 b6 compressor clutch fell off.
  1. Air Bag control module
    By Turkster in forum For Sale/Wanted - Audi Parts
    Last Post: 2nd December 2011, 22:46
  2. Engine Control Module - Fault code
    By way318 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd May 2011, 12:27
  3. control module fault
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2011, 23:58
  4. Air Con Fault
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th May 2008, 08:03
  5. Air Con Fault
    By wallacr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th May 2008, 21:57
