Backdraft MotorsportEM Tuning
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Audi A3 Air Duct Sensor Location & VCDS G89 Sensor reading -50 degrees
    Hi Sorry for the x-post which I had posted in A3 specific section but think it may be better suited for air conditioning.
    Here is my original post.
    G89 Air Intake Temp Sensor Location
    I took the car to my regular mechanic today who is very good with VAG cars in an attempt to replace one of the G89 sensors (3D0 907 543 A)
    I took along my laptop loaded with etka so we could try identify the possible locations that the sensor.
    A few hours has been spent and we are now none the wiser to it's location.
    We fear that it's a dash out job as we need to access the aircon connection box. (1K2 820 353)
    Is there anyone that can help as I fear that I might have to take this to main dealer and pay mucho bucks to rectify a £20 sensor.
    It's deffinelty not the G89 sensors in the outer vents as we disconnected these and checked with VCDS and still the elusive sensor read -50 degrees.
    We found this dodgy sensor after recharging the aircon to eliminate the permanant econ light issue.
    Here's hoping someone knows where it is.
    Tony.
    Apr 2011
    Ross-on-Wye
    25
    Post Thanks / Like
    I have the same issue wandering if anyone has any input ?
    Regards
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Check the other thread. It did come to a conclusion.
  1. G89 Air Intake Temp Sensor Location
    By tbcuprat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2012, 21:45
  2. Replies: 2
    Last Post: 25th June 2011, 12:13
  3. Audi A4 2.0TDI 170 Oil Sensor Reading
    By Stevej69 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd April 2011, 22:53
  4. Coolant temp sensor & air con ?
    By Jonion in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2010, 18:35
  5. Repalcement Air Filters & MAF Sensor Myth
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2006, 19:33
