KowalskiBackdraft Motorsport
    gynads's Avatar
    Oct 2009
    339
    Post Thanks / Like
    Pressure switch failure (07 S3 8P)
    Hi all,
    After parking my car up I jumped out to hear a hissing noise, thinking I had a radiator failure, i popped the bonnet to find gas leaking from a switch on an air con pipe on the offside front of the engine bay, behind headlight. I think it's the high pressure switch. It looks like the bladder separating the gas from the switch has failed resulting in the connector popping off and losing all it's charge. I'm currently offshore so cannot supply a pic, but it looks like a 5/8" pipe with a stabbing on and a switch/connector attached. Looks like a bit of a pain to replace
    Any help/advice would be greatly appreciated. I know a good independant VAG specialist, and also someone who can vac & charge the system for free.
    Adam
    gynads's Avatar
    Oct 2009
    339
    Post Thanks / Like
    Ok, anyone with ELSA want to have a quick look for me?
    gynads's Avatar
    Oct 2009
    339
    Post Thanks / Like
    Anyone?
    Aug 2011
    Post Thanks / Like
    had the same issue
    i had the same issue on a 07 A3 8P. the high pressure switch failed and the gas and oil leaked out. Easy replace. just take out the fans, four screws. the intake box for more room and the bottom engine cover to access the bottom fan screws and to use a 17 spanner on the switch. unscrew the switch (1K0959126D) replace the O ring also. gas up and its done. There was a fault with the original switch and you can see where they made changes to the new one.
  1. Help need pressure switch plug
    By mike-turbo in forum Air Conditioning
    Last Post: 30th November 2009, 17:44
  2. Boot switch failure
    By S4quatt in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 22:02
  3. Pressure Switch
    By henry74 in forum Air Conditioning
    Last Post: 25th June 2009, 12:55
  4. Oil pressure switch on A8 2.8 V6
    By mikeem in forum A8/S8 forum
    Last Post: 11th October 2008, 14:23
  5. 2002 A6 2.5 TDI G65 Pressure Switch Failure / Access
    By fergusd in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 2nd February 2008, 17:32
