KowalskiVAG Check
    Oct 2010
    Post Thanks / Like
    Climate Control Fault Codes
    I have the following messages for my Climate Control:
    1 Fault Found:
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 35-10 - - - Intermittent
    1 Fault Found:
    01320 - Control Module for Climatronic (J255)
    49-10 - No Communications - Intermittent
    Does anyone have any ideas?
    Thank you in advance.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Does the climate control work okay? If you clear the fault does it come back?
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
