DPMBackdraft Motorsport
Results 1 to 8 of 8
    redmanphil's Avatar
    Aug 2009
    Cheshire
    45
    Post Thanks / Like
    A3 8P - Fans like a jet engine
    Hi all,
    Doesn't matter what temperature or fan speed I set on my climate. The fans under teh bonnet go mad. Soon as I switch the ECON button on, within 2 secs is slows down and stops, turn the ECON off and the jets re-power up.
    ANy ideas what this could mean? Cheers
    2003 A3 8P 2.0 FSi
    2003 Audi A3 2.0 FSI Sport - Black
    2003 SEAT Leon Cupra R - Platinum Grey
    2000 VW Golf GTI Mk4 Turbo - Dragon Green
    1998 VW Golf SE Mk4 - Black
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Hmm not sure at the moment. It definitely needs looking at with VCDS though mate.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,084
    Post Thanks / Like
    Theres a thread on here somewhere with a few people having this problem (myself included).
    Through VCDS I get this fault:
    18354 - Control Module 1 for Coolant Fan: Defective
    P1946 - 004 - No Signal/Communication - Intermittent
    As soon as I find out how, I'll get round to replacing mine, see if that fixes the problem.
    Audi A3 2.0TFSI S Line SE DSG
    Cruise Control | Ambient Lights | LED Lighting | Full Leather | RNS-E MK2
    OEM Bluetooth | AUX | CH/LH Lights | MFSW | S3 Pedals | BFT Remap
    JMB Retrofits - North East Retrofit Company
    digzz's Avatar
    Leave It YEAHHHHHHHHHHHHHHHHHH
    Jan 2009
    London
    954
    Post Thanks / Like
    Quote Originally Posted by jb0o View Post
    My fans don't run at all even with the air con on and this same fault code comes up......Did you manage to solve your problem?
    Banned
    Aug 2010
    823
    Post Thanks / Like
    Quote Originally Posted by digzz View Post
    fuses on top of the battery..... you may find that if you let your car stand, it will boiler over
  7. Thanks digzz thanked for this post
  8. #6
    Banned
    Aug 2010
    823
    Post Thanks / Like
    did you fix it dizz? the fuses may look ok inside, but what you may find is the one that controls the fan module gets hot enough to melt the plastic around it thus covering the actual contact area in a very thin layer of plastic a bit of enry cloth does the trick here along with a new fuse, AA guy that checked the car over when it overheated said they were ok, after a fan control module and numerous sensors, i worked out it was the fuse!
    mate had the same problem on his golf, but for his abs pump (light kept coming on), 3 pumps later and numerous amounts of cash later..... i poped round and because of my experience, solved his problem with 2 minutes work!
  9. #7
    digzz's Avatar
    Jan 2009
    London
    954
    Post Thanks / Like
    Quote Originally Posted by colicabcadam View Post
    Yes I found out it was a fuse in the fuse box......But I also had a previous problem with the fans not stopping when the engine was off. So I had to replace the fans ...which was £240 .....
    "Digzz" Work In Progress
    http://www.audi-sport.net/vb/new-a3-...-progress.html
    Parts List For a 2009-2010-2011 Conversion for a Pre-2004-2008
    http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/121130-parts-list-2009-2010-2011-conversion-pre-2004-2008-a.html
    2003 A3 2.0 TDI 3 Door – Panther Black - Full Front End Conversion 2011-S3 Rear bumper- L.E.D Lights - S-line Flat bottom Steering wheel - S3 Pedals - S3 Vents
  10. #8
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,200
    Post Thanks / Like
    Common fault on VAG cars, we has the fans go on a 2003 Mk4 Golf and 2005 A3 Sportback....
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
