DPMEM Tuning
Results 1 to 7 of 7
    Aug 2010
    Post Thanks / Like
    1/2 air conditioning
    I have an Audi A4, 2003, 1.8-T. The air conditioner works on the driver's side. The air is coldest from the fan that blows on the front windshield. However, no cold air comes out on the passenger's side of the car. The fans blow, but absolutely no cold air comes out on that 1/2 of the car.
    What is causing this? How do I fix it?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Re: 1/2 air conditioning
    It's most likely the actuator which controls the source of air (hot or cold) to that side. You should have it looked at with VCDS (see the map linked in my sig to find someone in your area) to confirm it.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    Aug 2010
    Post Thanks / Like
    I tested the heating system. I can only get the two sides to work together when they are at 85 or on "HI." Otherwise, they just circulate air. When I put both sides down to 80, the driver's side blows cool air.
    could this still be the actuator?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Yep sounds like it mate.
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    241
    Post Thanks / Like
    I have this problem now when my blowers are on the passenger side stays ob hot no matter what I set the temp at. What could this be
    Apr 2011
    Post Thanks / Like
    Yeah...I have a related issue.
    When I am in auto mode and the temp is set to a cooler mode, after a bit of driving, the air from the outter windows starts blowing extremely hot, but the vents in the center of the car remain cool.
    Are there multiple actuators, or is there just one that is not working properly?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    I there are a few yes mate. Sounds like actuators are the problem
