DTUKAWEsome GTI
    Apr 2010
    Post Thanks / Like
    A8 Flat battery, boot won't open with key
    Hello, I have a A8 3.7 Sport 2001 model, battery totally flat overnight, key is spinning in boot lock so cannot access battery.
    I have been told that there is a charge/boost point under bonnet but can't find it.
    Does anyone know where it is or if it does not exist how do I get enough charge into the battery to use electronic key?
    Please please help, car is dead.
    Thanks, Dave
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Post Thanks / Like
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    May 2010
    Post Thanks / Like
    Hi Dave - I have a 2000 Audi S8. Same problem as you. Did you get an answer ?
    Thanks, Lyndon
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    Post Thanks / Like
    take it that link was of no use???
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,842
    Post Thanks / Like
    If you can open the bonnet, stick 12v (either a battery charger or another battery/jump pack) onto the starter motor or alternator studs, and ground the other lead on the engine block.
    Alternatively you can do the same at any permenant 12v source on the car, but bear in mind whereever you choose will be supplying power to all the cars electrics, so while hooking it up to the interior light seem like a good idea, you run the risk of melting wires.
    The central electrics panel (which is presumably behind the drivers knee bolster) has a suitable fat connection too.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
