Volks AutosJMB Retrofits
    imported_arnepaul
    A8 - Feet get wet!!
    I have a 1997 A8 4.2 Quattro and have a problem. When I corner there is water that drips - or pours - on my feet. It has to be condensation in or on the vents. It is really xxxx me off! I took it into a non-audi dealer, they said they though they were able to unplug the drain line, although my wife said it happened again! Any ideas? Someone told me it may be a heater box? What is the downside of not doing anything. It appears much better since the repair but still may be an issue. Arne Paul.
    Feb 2003
    43
    Re: A8 - Feet get wet!!
    Which passenger or driver? The A6 has the pollen filter on passenger side and a drain hole that can get clogged under the battery. Water builds up and when you go round corners sploshing through the pollen filter.
    Dont know about an A8 though.
    imported_arnepaul
    If you turn right, it's the driver's feet, if you turn left, the passengers. Thanks for your advice, I'll check it out. Arne
    Dec 2004
    I have the same fault on 97 4.2 , have you found the cause yet ? would be interested to know
    Dec 2004
    Very common problem. Please refer to this link for further information. I haven't tried this fix yet but I hope it helps.
    http://www.audipages.com/Tech_Articl...tordrains.html web page
    Dec 2004
    Thanks Nasti,
    Hard to believe that such a well built car comes with a no cost option like a foot spa !!! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
