Hey all, hope someone could help me...I am having issues with my parking sensors, I have the parking sensor plus upgrade with graphic - issue is when i engage the sensors, the screen pops up with heavy static like on a badly tuned tv. I have the VAGCOM and it states that there is an issue with Middle Right Front Sensor - i have inspected it, replaced the sensor at a rediculous cost from the stealer and checked all contact points. But the problem still persists...
the VAG COM displays the following:
Wednesday,04,November,2009,19:29:40:27752
VCDS Version: Release 908.0
Address 76: Park Assist Labels: 4E0-910-283.lbl
Control Module Part Number: 4E0 910 283 D HW: 4E0 919 283 C
Component and/or Version: Parkhilfe 8-Kan H12 0050
Software Coding: 0221008
Work Shop Code: WSC 131071 1023 2097151
1 Fault Found:
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 103390 km
Time Indication: 0
Date: 2009.11.04
Time: 19:29:20
Anyone able to decifer what it could be....I am considering purchasing a new harness as there could be a hairline split somewhere however the issue is only that one sensor (despite replacing it). Is there a way of coding the module to eliminate that sensor from radar checks? thats the easy way out but i would rather fix the problem....
Sorry for the long post but its necessary...
Thanks in advance
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 103390 km
Time Indication: 0
Date: 2009.11.04
Time: 19:29:20
Thanks in advance
