Sky InsuranceJuicy
Thread: MMI Problems
    Jan 2007
    12
    Post Thanks / Like
    MMI Problems
    Hi There,
    I have a 2008 A8 but I am continually having problems with the MMI System. It is intermittently cutting out whilst I drive along, as if the system is re-booting. It happens to radio, CD, Ipod, telephone and satnav, which ever is in use a the time. The fold out screen goes blank, then resets ad there is a loss of sound from the speakers. Only lasts a few seconds then all is well again. Does anyone have any ideas as it has now been in to the dealers 6 times but no faults show up on diagnostics and it always performs flawlessly while thy have it!!
    Any help appreciated.
    '03 A4 1.8T Avant Quattro Sport
    '04 A8 3.0 TDI Quattro
    '08 A8 3.0 TDI Quattro Sport
    Apr 2008
    54
    Post Thanks / Like
    I have no idea what the issue is fella, but persevere. Maybe take it to a different dealers to see if it misbehaves then?
    A8OC - The Potential Members Map
    Here now.......The A8 Owners Club here
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    437
    Post Thanks / Like
    It will be a power issue. Chances are teh MMI Control unit behind the glovebox. get the garage to remove the glovebox and check for loose connections, and even recommend that the MMI Control panel is replaced, as thats the unit that links to your screen, Nav, radio etc.
    Quote Originally Posted by NLM13 View Post
    Hi There,
    A6 Avant 2.7 TDI S Line (C6)
    MMI 3G
    RS6 LED headlights with AFS
    LED Tail lights
    Auto dimming rear view mirror
    Privacy Glass
    Engine re-map 45PS & 100nm extra
    Winter Pack
    Flat Bottom MFSW
    Rear view camera
    Post Thanks / Like
    Hi
    Did you manage to solve the problem with your MMI intermittently cutting out ?. As I have exactly the same problem on my A6 2.4L Quattro 2006. Not been able to ascertain the problem as yet. So any help would be much appreciated ?
    Jan 2007
    12
    Post Thanks / Like
    All sorted now
    Got the problem sorted, turned out to be a faulty AMI unit that kept reseting the system. Got it swapped for a new one and problem solved. It took a while to diagnose as we had to isolate each unit in the loop and see what worked.
