Hi,
Keep getting water coming into my air-con system. Definitely not coolant as can pump out via vent clean water.
Heard about this 'Botangs Hole' that is under the bonnet on the passenger side and can be accessed without removing the ECU, but I can't get near it. The floor is all wet on that side also but I don't see how this would let it into the air-con.
Have just had a lot of rain here and it now sounds like I must have about a gallon of water in the air-con system! Movement of the car sends it all sloshing over the inside of the vents. When the fan is on full I can see water splashing out the front and rear vents.
I just don't know how it is getting in, or how to remove it as pumping it out the vents with a tube isn't removing it all.
Can anyone advise?
Regards,
Barry.
PS : Reposted under a new thread as I had a different issue before.
LinkBack URL
About LinkBacks
Staz's S3
