VAG CheckKowalski
    Dec 2008
    Post Thanks / Like
    ESR and ABS lights on
    Guy's can anybody help. My ESR and ABS lights came on tested both and they don't work then yesterday my Glowplug light started flashing on my A6 1.9TDI auto. No brake lights work, she has done 96,000 but runs fine apart from the lights. The glow plug light comes on when the engine is started and the ESR and ABS comes on when in gear and foot off the brake. Thanks Steve
    meatychi's Avatar
    Jan 2005
    UK
    260
    Post Thanks / Like
    The flashing glowplug would suggest that there is a problem with your engine management and the ABS, could be sensors or your ECU, as you are experiencing both it could be your dashboard pod.
    You need to get it on a diagnostics tool really!
    1998 A6 Avant 2.5tdi Quattro Tiptronic Sport
    Flying Spanner's Avatar
    Oct 2008
    30
    Post Thanks / Like
    Its your brake light switch. Very common and part has now been modified.
