EM TuningBadger5
Results 1 to 7 of 7
Thread: S8 windscreen
    May 2003
    Wiltshire
    34
    S8 windscreen
    Ł600 [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    My insurance are sorting it, so hopefully I only have the excess to pay !
    Anybody confirm or deny this price ?
    Paul
    Sep 2003
    Sin City
    78
    Re: S8 windscreen
    That's about right for a heated one, a bit on the high side maybe (€795 here IIRC). If it's not heated it should be less IMO. Prices vary from €500 (Ł350) - €800 (Ł560).
    Code for the heated one is 4GM by the way (see sticker in service manual). You sure which type you need yet?
    May 2003
    Wiltshire
    34
    Re: S8 windscreen
    mine isn't heated. I thought it sounded a lot.
    Is there anything I need to look out for when they're changing it over ?
    Paul
    Bucks.
    67
    Re: S8 windscreen
    Hi Paul,
    Make sure the correct type of bonding gunge is used. About 4 years ago I had a 98 R S8 and its screen had been replaced by a non-Audi dealership. I could hear constant clicks and creaks from the dash area and eventually I got the screen replaced by Audi. This stopped all the noise which I think was caused either by the wrong bonding gunge (not flexible enough?), or by part of the screen touching the frame.
    As soon as you get it replaced, go for a drive with the heat full on to cause some expansion, and then open up the windows to get the inside really cold. Any clicks or creaks and I would tell them to do it again...
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Jon
    May 2003
    Wiltshire
    34
    Re: S8 windscreen
    Thanks Mutley.
    Sep 2003
    Sin City
    78
    Re: S8 windscreen
    Oh, and make sure you demand an original screen (with the Audi logo on it), otherwise you may end up with some imitation cr*p... [img]/ubbthreads/images/graemlins/wink.gif[/img]
    May 2003
    Wiltshire
    34
    Re: S8 windscreen
    I phoned my garage to check up on their expectations.
    Apparently using a non Audi sourced windscreen can invalidate your warranty (and the stuff they use to bond the windscreen)
    Anyway, they took my car away, and i just got a call to say my screen has a photo reflective coating on to reflect heat in summer ! (never knew you could get this, but I am happy!)
    Paul
