Chris NottBadger5
Like Tree1Likes
  • 1 Post By cocain
Thread: A few new fault codes.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,032
    Engine management light came on last weekend but went off the next day.
    Did a scan yesterday and found some new codes.
    I've removed the standard codes of fault handles, buttons and footwell heaters.
    Its on a 06 A8.
    Address 69: Trailer Labels: 4E0-910-383.lbl
    Control Module Part Number: 4E0 910 383 C HW: 4E0 907 383 C
    1 Fault Found:
    02539 - Terminal 30 from Control Module
    006 - Short to Plus
    This keeps coming back instantly.
    I've used tow bar and electrics with no issues. It all worked fine.
    I checked the wiring and it looked fine.
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 4E0 910 401 Q HW: 4E0 907 401 C
    2 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    012597 - Intake Manifold Runner Control
    P3135 - 001 - Lower Stop not Reached - Intermittent
    Glow plug is an old one and before the weather turns and I can't get out there, I think its time to get it fixed.
    Is it normally new glow plug?
    I think the intake manifold runner control is was cause my engine managment light to come on. I've not seen it before.
    Anyone got any ideas?
    Its not come back since.
    Address 28: HVAC, Rear Labels: None
    Control Module Part Number: 4E0 910 158 HW: 4E0 919 158 A
    1 Fault Found:
    00003 - Control Module
    003 - Mechanical Failure - Intermittent
    This is a new one and I hate it when it says mechanical failure.
    I got no idea what it is talking about.
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Control Module Part Number: 4E0 910 553 H HW: 4E0 907 553 F
    2 Faults Found:
    01577 - Turn-Off due to Over-Temp
    001 - Upper Limit Exceeded - Intermittent
    01772 - Signal from Level Control Pressure Sensor (G291)
    008 - Implausible Signal - Intermittent
    I'm going to rebuild the pump this weekend with bagpippingandy kit. Hopefully that will stop the two fault codes.
    I assume they came on cause of the piston ring aging?
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Control Module Part Number: 4E0 910 181 C HW: 4E0 915 181 C
    1 Fault Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Not seen this before.
    Battery has been fine. No issues.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    178
    No clue
    I wlould post this across the pond on audi world they'll respond in a jiffy as they are miles more active on their board
    ScottD3 likes this.
    Audi A4 TDI 130
    Remap
    18" Alloys
    Electric heated leather recaro interior
    Lowered bilstein suspension
    Alpine cd player Genesis amp Jl sub
    Ipod ashtray mount
    Audi A8 LWB 4.2 TDI
    19" 12 spoke alloys
    Walnut Trim
    Walnut steering wheel
    Silver Grey Platinum Leather interior
    Audio upgrade removed bose
    Audison bit one
    Morel speakers
    Genesis Amps
  1. Got few fault codes, help needed please as new to VCDS
    By JMB-S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th May 2014, 15:43
  2. New VAG COM fault code...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2010, 18:19
  3. Needle Lift Sensor G80 plus a few other fault codes
    By vrbob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2010, 13:52
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. New user to vag-com, help on fault codes please
    By Hightower in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th December 2009, 09:04
