Badger5Monster Motorsport
Thread: D3 Door lights.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    D3 Door lights.
    Went out for a drive last night and while admiring the amount of lights, LEDs and buttons in the cockpit I noticed that there's a thin illumination strip on the doors.
    3 out of the 4 are working but not the rear passenger door.
    First off, what are they called?
    I've been searching different words that I think are correct but I can't find anything on this.
    Second, how do I remove the door card to fix this?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2012
    1,837
    Is there a decorative trim panel over the top of it? On the A6 anyway the trim piece pops off and allows you access to the LED strip and the part number.
    If you need me to look up instructions on Elsa let me know.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    There is the wood trim but it looks like the strip part of the door under the trim. so no access from by removing the trim.
    I'll have a better look during the daylight.
    Also noticed one of my LED exterior door handle lights don't work.
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    178
    To remove the door trim you have to use a trim tool. start from the door hinge end and pry it off. Both the wood and ali trim come off in 1 strip. When you get to the other end do not pull as that end is hooked into the door and needs to be slid out.
    there are a few bolts to undo. 1 of them is hidden in a hole that you can see if you look carefully at the top of the door pocket that folds out. You have to do this whilst the pocket is shut. Then use the trim tool to ease and pull away the door card around the edges. Quite a bit of force may be needed and you probably may as well get a few spare clips which you may need if you are going to be investigating these areas.
    Audi A4 TDI 130
    Remap
    18" Alloys
    Electric heated leather recaro interior
    Lowered bilstein suspension
    Alpine cd player Genesis amp Jl sub
    Ipod ashtray mount
    Audi A8 LWB 4.2 TDI
    19" 12 spoke alloys
    Walnut Trim
    Walnut steering wheel
    Silver Grey Platinum Leather interior
    Audio upgrade removed bose
    Audison bit one
    Morel speakers
    Genesis Amps
  1. Door lights.
    By Aber-AUDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2009, 20:06
  2. Rear door light not working
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2007, 09:12
  3. Door light Switch Fault 1997 A8
    By axelfols in forum General Technical / How To
    Last Post: 26th July 2007, 21:50
  4. door lights???
    By terrysingh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st April 2007, 17:40
  5. Door lights fuses
    By PocketRocket in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2007, 21:47
