Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By S3P8
Thread: Cabin/Pollen filter
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Cabin/Pollen filter
    Hi, just wondering if this is an important filter to replace. I assume its the 2 boxes on the underside of the bonnet? I have been getting steamy windows for some time and cant seem to trace where its coming from. Cleared all vents and A/C ducts out but still the car gets steamed up. Anybody got any ideas? Thanks in advance.
    2,169
    Pollen filters should be replaced every year, and may be the cause. However there could couple other reasons, water getting into the car check front & rear carpets and push down as hard as you can to check to see if they are damp, also a leaking heater matrix will also cause the same problem.
    Jan 2011
    Scotland
    the air con drains are usually to blame, bit of a PITA to do but worth it, carpets and mats can soak up a LOT of water so best remove them to dry
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Thanks for the replies. I had the air con drains unblocked last year (full of crud) and the rain water drain outlets after the carpets where found to be soaked. This has resolved the wet carpets so I shall change the pollen filter and hopefully see a difference. I'll post the results once completed.
    Ch3tan's Avatar
    Nov 2013
    London
    43
    So Audi said my filter hasn't been changed by the previous owner... my full service is due in a year and I'm not willing to pay Audi 35quid for such a simple job before then. Does anyone know the part number of the filter Audi use? I've seen some on euro car parts but not sure which to get.
    2011 A3 140 2.0TDI Black Edition
    Oct 2013
    322
    Quote Originally Posted by Ch3tan View Post
    If theres more than one on EuroCparts buy them and take the one you dont need back for a refund, thats what Ive done in the past, you could also have a look at yours, should give you an idea...I'd get the carbon charcoal one, sorry cant remember the specific name but its a special type
    Oct 2013
    322
    Ps
    Activated carbon....theres a lot on there...might be best to check yours first
    Ch3tan likes this.
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Always thought you just needed the reg number?
  1. Cabin/Pollen filter....where on earth is it?
    By thehogester in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th July 2013, 16:20
  2. cabin/Pollen air filter
    By Mattblack2004 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd November 2007, 16:32
  3. Cabin Pollen Filter
    By jdp1962 in forum Detailing
    Last Post: 6th November 2006, 21:19
  4. Pollen filter...
    By darkmatter0 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2004, 19:52
  5. Pollen Filter
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2004, 11:28
