Volks AutosJMB Retrofits
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By jdp1962
Thread: Brakes....
    Dec 2013
    Peterborough
    Brakes....
    Looking at replacing the brakes on the A8 soon (possibly just fronts - noticed they smell a bit hot when used harshly, also arent as "sharp" as they need to be in a car that size to be honest - rears look fine)
    Now id like better brakes if im honest, where do you go for better brakes?
    Ill be honest its not something i've done for any car before! O_O!
    Any recommendations? I googled and had a brain meltdown haa
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    I think you have more chance of getting worthwhile information if you post this in the A8 forum.
    Maybe a friendly moderator will move it for you.
    Sandra likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,453
    Moved to correct section. x
    Dec 2013
    Peterborough
    A8 section is a bit quiet, was just asking in general where people go for better brakes etc - my first Audi ^^
    munchkincoupe's Avatar
    Aug 2010
    971
    By better brakes do you mean uprated pads and discs or do you want to fit larger calipers and then larger different discs and pads?
    May 2012
    Kings Lynn
    896
    Better A8 Brakes... you want a couple of flying saucers and pads to match on a car that size :P haha
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    Dec 2013
    Peterborough
    Not larger calipers just better brakes lol
    Aug 2010
    971
    I just fitted Pagid front and rear pads and discs to mine and they seem to be better than the stock Audi parts. You can get these from Eurocarparts - use discount code chill30 for 30% off
    Oct 2012
    East Kilbride
    343
    after trying loads of different disks and pads, I bit the bullet and got proper Audi ones... cost a bit more, but I've found them to be a lot better than others... including ECP ones.
  1. Front brake pads
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 16:30
  2. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
  3. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  4. S3 Brake Upgrades - not Porsche/Brembo
    Last Post: 25th January 2003, 17:05
  5. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
