Results 1 to 15 of 15
Thread: MMI issues
    May 2013
    Liverpool
    32
    MMI issues
    Morning all.
    The suspension section has disappeared from my mmi screen. I've lost a few other features from there. Can I re-activate these using vag-com? If so what would the path be..?
    This happened after we unlocked the hidden menus on the MMI.
    Thank you.
    Colin..
    Jan 2012
    1,615
    Hi Colin
    You're using 2G yeah?
    Go into the hidden menu, find Diag Settings, find APK 0 × 01, 0x0B, 0x0C then find the box for air suspension, scroll down and press Accept Changes, exit the hidden menu by pressing RETURN a few times then reboot by holding in SETUP+Central MMI Knob+Upper Right inner key.
    May 2013
    Liverpool
    32
    Quote Originally Posted by a6-chris View Post
    Hi Colin
    Chris.
    Thank you. I'll give it a go when he arrives with the kit.
    Whilst your here. Do you have the path for the dial sweep and alarm chirp.?
    Colin .
    Jan 2012
    1,615
    Going into the hidden menu won't need VCDS as you've already enabled it.
    Hold in CAR+SETUP (may take a couple of goes to get the timing correct) then go from there.
    What else have you lost?
    Needle sweep won't work iirc but chrip on lock is usually in Module 46 (Central Conv) then do the simple sum beside Alarm Chirp on Confirmation or something similar to that.
    May 2013
    Liverpool
    32
    I've also lost the user interface for the fingerprint start, but that never worked anyway. Kept stating transmission error....
    i can't remember what else, probably won't until I come to need them....twonk hey..:-)
    May 2013
    Liverpool
    32
    Once I have reactivated the hidden menu can I do most things from there without the need for the vag-com. It's not my kit. The guy is coming soon....?
    Jan 2012
    1,615
    Quote Originally Posted by Col Clarke View Post
    Ah you turned it off, ok. You can only do stuff in the hidden menu without VCDS, everything else will need the kit.
    Fingerprint is in the same menu as the Air Suspension so hidden menu, find Diag Settings, find APK 0 × 01, 0x0B, 0x0C then find the box for Fingerprint, scroll down and press Accept Changes, exit the hidden menu by pressing RETURN a few times then reboot by holding in SETUP+Central MMI Knob+Upper Right inner key.
    WARNING do not press anything you're not sure of in the hidden menu as it can mess things up bigstyle.
    May 2013
    Liverpool
    32
    No worries there mate. I'll give them go when he lands. As I say the fingerprint bit never worked anyway. Apparently it did once, but stopped after the guy installed the MMI update! the one before the most current .....
    May 2013
    Liverpool
    32
    Chris. Can you think of any other features I could activate whilst my mate is here. Thanks mate...
    Jan 2012
    1,615
    Passenger mirror dip on reverse if the mirror module supports it, passenger door module.
    Battery meter in the hidden menu if you don't already have it.
    MMI 2G is quite limited for VCDS mods.
    May 2013
    Liverpool
    32
    the mirror dips already, no battery meter though mate.....
    Jan 2012
    1,615
    3. Battery Meter
    After MMI restart and Hidden Menu enable - press Radio then hold in Setup + Car for a few seconds (it might take a few times to get timing correct)
    [Select] DIAG SETTINGS
    [Select] Car Menus Maske
    [Select] Battery Level
    Scroll to Accept Changes
    Press RETURN 3 times
    Restart MMI using Setup + MMI Control Knob + Upper Left Inner Key - release
    Do you have visual parking lines when you select reverse?
    Ie like this on my A6?
    May 2013
    Liverpool
    32
    3. Battery Meter
    never seen that either Chris.
    Jan 2012
    1,615
    Your parking may or may not support it, go into the Parking Aid module (if the sensors are factory fit) and see if there is any available coding changes for visual lines.
    May 2013
    Liverpool
    32
    Didnt have that module Chris, but the main feature- my air suspension is back. Thank you for your help mate..
    Col...
  1. help...urgent mmi issue during upgrade
    By vw754 in forum Satellite Navigation
    Last Post: 25th March 2013, 17:52
  2. A4 MMI Iphone / Ipod Issue
    By Fandango80 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 2nd March 2013, 13:40
  3. More MMI issues
    By poweller in forum New A3/S3 (8V Chassis)
    Last Post: 6th December 2012, 20:51
  4. MMI/Multi CD changer issue
    By linners in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 14th November 2012, 09:40
  5. Please help me!! iphone MMI queries/ issues/ ball ache
    By pea. in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd June 2011, 17:49
