EM TuningChris Nott
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Col Clarke
Thread: Bluetooth Module location 2005 Audi A8
    May 2013
    Liverpool
    32
    Hello.
    Can anyone please advise on the exact location of the Bluetooth Module in my audi a8. I've recently fitted a Viseeo MOST kit and at the moment the MMI is struggling on which phone set up to use, be it the already installed Audi kit or the Viseeo. The Audi kit is the old style which has the SIM card beneath the handset in the armrest so I cannot connect to this with my phone. Apparently on the new style handset you can connect any phone to the system.
    My thoughts are - if I disconnect the audi kit from the bluetooth module then the MMI with hopefully see the Viseeo and connect every time.? Just out of interest I disconnected fuse number 13 ( phone and mmi) and when I placed it back in the phone prep did connect with no issues to the Viseeo kit. It also worked fine until I switched the engine off.
    The Viseeo kit is attached to the rear of the cd changer via the fibre optic cable.
    Your thoughts please ?
    Thank you in advance
    Colin..
    Jan 2012
    1,599
    I know on the A6 its below the carpet, below the front passenger seat.
    You will need one of these http://www.ebay.co.uk/itm/Fiber-MOST...item2ec7d61e68 to plug into the fiver loom when you remove the bt unit.
    I'd also be removing it from the cars memory via vcds too
    May 2013
    Liverpool
    32
    Thanks a6 - Chris. God, it's never easy is it. :-). Any thoughts as to why the Viseeo kit sometimes connects and other times it dosnt? It would be nice if there was a fuse I could remove to disable it that way.
    Jan 2012
    1,599
    You may find that when you remove the Audi BT module it will work perfectly
    Remove it altogether then you will remove any chance of another problem possibly occurring in the future.
    May 2013
    Liverpool
    32
    Will it not work if I have it removed from the vcds. Will the car then not see it to connect.?
    Jan 2012
    1,599
    Needs to be removed with vcds and physically as the unit will still be present in the MOST ring.
    Purchase one of those loops I linked above and plug this into the plug that you will remove from the Audi BT moudle, problem solved.
    May 2013
    Liverpool
    32
    Okay. So the item from eBay is going to needed regardless? I take it this closes the fibre loop? Be helpful if Viseeo told us this before you buy the gits....
    Jan 2012
    1,599
    Yes you will need that and vcds to tell the car the BT has been removed.
    May 2013
    Liverpool
    32
    Got ya. Ignore my last question. You've answered it already mate. Thanks .......
    May 2013
    Liverpool
    32
    Thanks for your help a6-Chris.....
    a6-chris likes this.
    Jan 2012
    1,599
    No problemo
    May 2013
    Liverpool
    32
    Quote Originally Posted by a6-chris View Post
    No problemo
    Hey a-6 Chris. You there...??
    May 2013
    Liverpool
    32
    Hello Chris.
    Quick question mate - I've purchased the optic cable and all is now fitted to my A8. It's working a treat, connects every time. - I have however lost my voice command feature.! Is this normal?
    cheers Chris
    Jan 2012
    1,599
    Hi Col,
    Sorry I haven't been in contact, had a load of stuff landed at once!
    Yeah I can only assume thats normal as you've removed the original BT module.
    Is it all working AOK now?
    May 2013
    Liverpool
    32
    Hi Col,
    That's okay mate. Yes all is great now. Sourced the same cable from the UK in the end. But yep, the viseeo kit is working fine..
    Connects everytime, quality is spot on. The car didn't need coding either. :-)
    So I take it the BT module and voice command are one in the same? Loved that voice command an all.....the only women that wont tell me where to go when I told it to do something....
  1. Bluetooth module location its not under passenger seat
    By a3_sline_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2013, 18:00
  2. Best location for OEM bluetooth module?
    By a6-chris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2012, 17:27
  3. Bluetooth module location??
    By swatchuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th February 2012, 16:02
  4. Genuine Audi bluetooth module and antenna
    By evapor8 in forum For Sale/Wanted - Audi Parts
    Last Post: 11th January 2012, 07:58
